Old 08-17-2021, 03:46 PM
kings79's Avatar
kings79 kings79 is offline
Default RAM & Pro Tools
This could be a big topic and we may need some Avid people to help. But...
RAM. What tasks does RAM get utilized in Pro Tools. What uses alot of RAM and what doesn't.
I want to know everything from session loading to hitting play.
RAM & Pro Tools.
Re-Recording Mixer/Sound Designer
Sydney Australia
OS Monterey
ProTools Ultimate 2022.4
Presonus Quantum 4848
Mac Studio M1 10 Core, 64gig RAM
Sonnet Echo dual NVMe TB Dock
Blackmagic Decklink 3G
Old 08-17-2021, 04:53 PM
EGS's Avatar
EGS EGS is offline
Default Re: RAM & Pro Tools
Scroll down to "Memory": https://www.pro-tools-expert.com/hom...pro-tools.html
Click for audio/video demo
Click for resume
Old 08-17-2021, 05:01 PM
kings79's Avatar
Originally Posted by EGS View Post
Thanks man. That is helpful. But I'd like to know exactly what is using RAM and when.
PT Expert
"Memory - The memory meter shows how much system RAM is being used by Pro Tools. If you are using Pro Tools 10 and earlier, which are 32 bit applications, then this is limited to around 3GB, irrespective how much RAM you may have installed in your computer. Pro Tools 11 is a 64 bit application, so is theoretically able to access as much memory as you throw at it. Plug-ins, particularly Virtual Instruments with large libraries use lots of memory so it is good to have as much in your computer for Pro Tools to access. However you need to remember that Pro Tools accesses RAM for other functions too, this includes; The Audio and Video Engines, plug-ins and disk cache (if available & enabled)."
Sydney Australia
OS Monterey
Old 08-17-2021, 05:21 PM
EGS's Avatar
EGS EGS is offline
Originally Posted by kings79 View Post
...But I'd like to know exactly what is using RAM and when...
Perhaps you could test on your own rig:
Boot computer, quit all apps, & check mem usage in Activity Monitor: https://support.apple.com/guide/acti...ctmntr1004/mac
Launch PT, video engine off, no disk cache, no VIs. Check Activity Monitor.
Video engine on: check Activity Monitor.
Disk cache on and set to ??? size; check Activity Monitor.
Add a VI; check Activity Monitor.
Add other VIs etc etc etc
Click for resume
Old 08-17-2021, 05:22 PM
kings79's Avatar
I've done all that. Ther is too much lag.
I want to hear from the experts for a definitive answer.
Sydney Australia
OS Monterey
Old 08-17-2021, 05:33 PM
its2loud its2loud is online now
Plug-ins, VI’s, and Disc Cache. Avid Video Engine uses RAM too if you’re using that.
Old 08-17-2021, 09:32 PM
kings79's Avatar
What about Loading Sessions, Audio Suite, the Mix Engine, channel meters ect..?
yes I use the Video Engine.
Sydney Australia
OS Monterey
Old 08-18-2021, 04:23 AM
There's no real numbers on that that you'll find. Knowing what each little bit takes up ram-wise won't tell you anything. It's the program as a whole you should be concerned about. I have to ask - why do you need to know all those kinds of details? Or is this just some academic exercise? What exact problem are you chasing? You mentioned something about lag. Lag where? In what operation?
Jack
QAPLA!
Old 08-18-2021, 04:42 AM
JFreak's Avatar
JFreak JFreak is offline
This.
Algorithmic (a.k.a. normal) plugins do not consume much memory, you could have lots of those in sub-gigabyte systems two decades ago. Audiosuite as well, not a problem as it is CPU constrained nonrealtime process. Video Engine should be turned off if you do not need it and using Disc Cache is optional, but here's the thing... some VI's are optimised to use as much memory as there is while some older ones (such as Synthogy Ivory II) are optimised to use as much storage performance available, reducing memory footprint and making your storage scream.
I am currently testing a fully loaded M1 Mac Mini which obviously maxed at 16GB memory. No problems so far (except Sonnox Pro Codec does not work yet), but adding huge amount of VI's becomes a problem at some point. Looks to be enough for my workflow though.
Janne
Old 08-18-2021, 04:47 AM
Originally Posted by JFreak View Post
This.
And some vi's like the East West Play engine can either run from disk or load all into ram on a per voice instance. And you have those like Kontakt that can load the initial bit of sound and stream the rest. There are no real hard and fast numbers. And if you have a modeled vi like some pianos are they use a minimal amount of ram.
Jack
QAPLA!
FS: Pro Tools HD 8 + Pro Tools HD 9 + Pro Tools 9 Bundle iLOK license Delta Music Belgium Buy & Sell 1 02-27-2019 03:33 PM
