For All Kontakt Users !
Hello Mates
I was having issues using Kontakt 4 on Pro Tools, frequently when i am using it sometimes all the instruments i've loaded in it disappear all of a sudden !! and i loose all my patches and tweaks !!!!!!! I am using Pro Tools 8.0.4 With Kontakt 4, Does it have to be 4.1.1 ??? or it is supposed to work with 4 ?? |
Re: For All Kontakt Users !
I have version 4.1.0 which i think is the latest and its working fine! If you are losing your library then check your hard drive where your NI library samples are stored, could be a problem with your hard drive! Chris
Anymore Suggestions ?
not the problem I had with K4. After updating to 4.1 K became "sluggish" and I went back to 4.0.5. All fine so far
As crizdee says: check your library path
PT HD 9.0.6/Win 7 pro SP1 64bit/Q6600/EMU1820m PT 9.0.6/HP 8560w/ProFire2626+Octane |
Should you use an usb drive or firewire drive to store your samples?
Firewire, absolutely! Not usb.
Even better than firewire would be internal or external sata drive. |
Any Kontakt users? | pasanta | Pro Tools 9 | 22 | 02-14-2013 07:11 AM |
Any NI Kontakt 2/LE 002 users out there? | Mishima | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-22-2005 02:11 PM |
Kontakt users | Lalaman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 01-31-2003 05:34 PM |
Any Mac Kontakt users? | CV | Pro Tools TDM Systems (Mac) | 12 | 09-30-2002 03:01 AM |
any Kontakt users? | kimaguresound | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 07-25-2002 05:28 PM |
