Wiring problem with Procontrol
We have a 25 pin D-sub - XLR cable from Hosa with standard wiring. After reading the documents about Procontrol output wiring we got confused. According to "Late breaking tech issues" the manual for Procontrol is incorrect or is it the physical outputs from the Procontrol unit that is wired incorrectly?
Do we have we to change polarity for the cables or not? And if so why not on the AUX cables (says so in the "Late breaking tech issues"). If Digi or anyone else could clarify this we would be very happy! Thanks in advance ------------------ Best regards Holger Netterby ACSE
Best regards Holger Netterby ACSE |
Re: Wiring problem with Procontrol
If I'm not mistaken, the issue is of 'relative phase'. You just need to swap pins 2 and 3 on the main outputs...
Is this a 002 wiring Harness Problem? | pecranley | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-05-2011 01:15 PM |
Original ProControl Wiring | michael c | ProControl, Control|24, Command|8 | 1 | 04-08-2009 09:21 AM |
Digi: Original ProControl Wiring | michael c | Pro Tools TDM Systems (Mac) | 3 | 04-06-2009 03:41 PM |
002 wiring harness problem - again | DodgeSongs | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-21-2006 08:35 AM |
Wiring problem with Procontrol | Wooster | Tips & Tricks | 0 | 11-01-2000 09:32 AM |
