Old 03-14-2001, 10:38 PM
JaredVogt JaredVogt is offline
Default Plugin paramters up on the faders - Procontrol vs Control 24
Greetings,
Got a question. I have a Procontrol with 3 expansion units. When I switch and pull up plugin parameters to faders, I only get parameters on the base unit (leaving 24 faders sitting idle) - of course some plugs have beaucoup parameters. It sounds like on the Control 24, all 24 faders are used? If this is the case, can't we Procontrol owners get the same thing - have it use as many faders as it can?
Thanks,
Jared
Old 03-15-2001, 11:07 AM
Axis Audio Axis Audio is offline
Default Re: Plugin paramters up on the faders - Procontrol vs Control 24
On my Control 24 I can utilize all of the faders/ encoders for parameter control as well as "bank" to the next set of 24 if necessary. On some plugs I have needed the second bank set.
Barry Sturgis
Axis Audio
Old 03-15-2001, 11:58 AM
Jules Jules is offline
Have we been left behind again? Please dont tell me the trim/scrub wheel WORKS on the Control/24.
Jules
Jules
London, UK
Come hang with us here!
www.gearslutz.com
ProControl PT9 Faders not displaying ch3-6 sean c ProControl, Control|24, Command|8 1 03-26-2011 02:05 AM
control plugin parameters and sends with faders on MC Control jacko Artist Series 1 01-03-2011 04:12 AM
Procontrol Faders pmichalak ProControl, Control|24, Command|8 1 03-09-2004 12:52 PM
procontrol faders aren't accurate? uno1234 ProControl, Control|24, Command|8 7 06-12-2001 12:37 AM
plugin control by faders Chris Lambrechts ProControl, Control|24, Command|8 2 01-14-2000 10:52 PM
