Looking forward to this...
Well, the parts for the new Windows 7 computer are ordered, I have downloaded Pro Tools 9 and have the license on my iLok, and I have a Lynx Aurora 16 with LT-FW card for Firewire connection on order. I'm going to try out PT9 with my 002 Rack first to make sure it's working properly, then I'm going to try using the Aurora with it via Firewire. If all goes well this should be one killer system. Wish me luck! :)
Joshua L. Decatur, AL |
Re: Looking forward to this...
Keep us updated. Interested in your build and how the Lynx card works out for you. Considdering something similar in the future.
Will do. The remaining computer parts should be here today. The Lynx is here already but I'm waiting for the LT-FW card to come in. I'm hoping for it to arrive sometime this week.
So if I assume correctly, you get premium conversion with the Lynx Aurora, and up to 32 channels of i/o with the LT-FW card? Is this the way it works?
PT11, Windows 10 RME Babyface
bump
Do some research on the FW card performance on the Auora's, I hear it's not so good. I'd get the pci(e) card instead. I love the Auroa's!!!!!
HD Native Pcie, PTHD 11, PT12 Vanilla, Omni, Lynx Aurora 16, 192 I/O (16 in/8 out), 24 Fader D-Command, lots of preamps and compressors. MacPro 5.1 (12) Core (2009 MacPro 8 Core Upgraded to a 12 Core MacPro), 56 Gig Ram, SSD System & 3 - 2TB Drives, OSX 10.9.5, Windows 10 Via Bootcamp |
Well, have hit an interesting snag. The driver for the LT-FW allows you to change the ASIO buffer setting, but none of the values listed are compatible with PT9. It requires you to have a buffer of a multiple of 32 (32, 64, 128, 256, 512 or 1024) samples. None of these are available options for the LT-FW.
For the time being I have PT9 running with my Digi 002 Rack. I'm going to give it a little time to see if new drivers or a Pro Tools update will be forthcoming to fix this compatibility issue. If not I'm going to consider picking up a used HD Core card or possible the HD|Native route, since the Aurora with the LT-HD card has a proven track record. Incidentally, I think this may be a PC-only issue, as the LT-FW card has native support with Macs instead of using a Lynx driver. I'm not certain of that, though.
Hey Joshua,
I ran into the same setup with Aurora FW-LT running Windows 7 + PT 9. Any news on the updates? I was reading up on the supposed release of LT-USB which supposedly supports PC's. Not much help that is for my existing LT-FW on the Aurora 8's though. I can't get it to take ASIO4ALL either. |
After wrestling with it for a couple of days, I set it aside and went back to my PTLE 8.0 rig. Then I ran across an HD2 (non-Accel) rig on eBay and put in a lowball bid just for laughs ... and actually won the thing for a very low price. So I swapped the LT-FW card for an LT-HD card, and have the Aurora 16 working with an HD1 rig and PT9 on Windows 7 64-bit. I am going to either get an expansion chassis or find a motherboard that will support multiple PCI cards with an i7 processor so I can use the Process card. Of course I still have to move all of my plugins over...
The nice about this is that I still have my LE rig, which will eventually get updated to Windows 7 and Pro Tools 9, and when that happens I will have the full CPT2 functionality on the 9 rig with the HD license on my iLok ... but I spent less money on the HD cards and the HD9 upgrade than the cost of the toolkit. So it was worth doing even if I decide not to use the HD rig. And I can put the old rig in a portable chassis now and start using it to record our band's live shows. Or use my laptop and an eSATA drive to do this along with my 002 Rack.
HUI support going forward or not? | pasanta | Pro Tools 10 | 1 | 10-25-2011 05:18 PM |
How come when I fast forward are my | renips1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-23-2010 08:58 PM |
What releases are you looking forward to? | Stiff | General Discussion | 1 | 06-30-2005 12:42 PM |
Gigs I'm looking forward to... | K.B. | General Discussion | 2 | 01-18-2005 08:45 PM |
Albums I'm looking forward to... | K.B. | General Discussion | 0 | 01-17-2005 04:11 PM |
