Old 09-17-2004, 09:15 AM
drguitar drguitar is offline
Default What are the absolute best video parameters for PT
We are running an HD 1 system here on a dual processor G4. Panther running PT TDM 6.4. We seem to have figured out that the movie needs to be encoded in DV or dv/dvcpro to run well (or maybe that's just to be able to run out of the canopus). But we have only tried that with nothing but basically the video in the session and are worried about it possibly getting bogged down once the session gets thick.
I believe the old method of thinking in OS 9 was to limit the video file to 2 GB. I think that shouldn't probably apply anymore with how well panther takes advantage of processors, RIGHT?, especially dual processors and that the graphics card does most of the work in panther....am I correct about that thinking?
Also, does it matter what the resolution is or the what the movie data RATE is? We obviously would love to hear that file size, resolution, and data rate are not issues at all and that the only thing that is important is to have our video in the dv/dvcpro codec. so that it will look as good as possible both when using the canopus for output and when NOT using the canopus.
iMac 2017 4K Quad 3.6 GHz i7
32 GB RAM
Presonus 1818VSL
PT Ultimate
Old 09-18-2004, 01:02 PM
Pot-Belly Pot-Belly is offline
Default Re: What are the absolute best video parameters for PT
Sorry...
I don't have an answer for you, I was wondering about the Canopus Video system you have.
Is it the ADVC 100 or similar.
Does that work for you for outputting video from PT?
cobain@pbp
Old 09-19-2004, 02:03 PM
yes, I have the advc 100
I use it at my home studio for outputting video from pro tools LE and we also have one in the studio I work in most of the time where we use it to output video from an HD 1 system.
Using it on the TDM system requires you enter a frame offset to sync the picture w/ the audio moreso than on my LE system
32 GB RAM
Presonus 1818VSL
PT Ultimate
Old 09-20-2004, 12:37 PM
bump.....anyone out there?
32 GB RAM
Presonus 1818VSL
PT Ultimate
Old 09-20-2004, 06:21 PM
MissHiss MissHiss is offline
I've used full resolution, full motion NTSC DV encoded Quicktimes in PT all the time. I'm told there can be a bit of a time code drift over time, but personally that's never been an issue for me. However, I don't believe I've ever run more than 20 tracks in a video-based session. I've never had any problems at all. None.
Optimal video parameters for Pro Tools roubignolle Post - Surround - Video 5 01-11-2010 07:45 AM
Absolute pan linking ? Help please... Aquarius Pro Tools TDM Systems (Mac) 1 08-09-2006 10:48 AM
What are the absolute best video parameters for PT drguitar Pro Tools TDM Systems (Mac) 10 09-22-2004 08:20 PM
Firewire... The absolute best?? duende Pro Tools TDM Systems (Mac) 12 11-13-2002 09:25 AM
Absolute BEST CPU set-up for 001 imp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 08-13-2001 11:27 PM
