Ethernet Card for C24
Which Ethernet card has been endorsed for use with C24, if the built-in ethernet port on the PowerMac is being used for networking?
Thanks. |
Re: Ethernet Card for C24
Why wouldn't you use a hub...?
Marcello |
The reason I don't want to use a hub is because I want to keep my PowerMac's Gigabit Ethernet.
A Gigabit hub is fairly costly. Also, the C24 only requires a simple 10BaseT connection. So it's better to use a cheap Ethernet PCI card to connect to the C24. And continue using the Gigabit Ethernet on the PowerMac for real networking and file transfer. Isn't that better? |
Whenever you're ready Digi Tech Support.
Digi,
What's up with the answer? |
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:<HR>Originally posted by Samhein:
Which Ethernet card has been endorsed for use with C24, if the built-in ethernet port on the PowerMac is being used for networking? Thanks.<HR></BLOCKQUOTE> I don't know that any add-on ethernet cards have ever been tested with Control 24, much less endorsed. I think you will have to rely on the testing of other users or your own testing for this configuration. If we get some feedback from Sales about any facilities that are using such a setup, we will be more than happy to pass that along. And please share your results if you do try an inexpensive ethernet card. I don't know of any reason why that should be any more problematic (or better) in performance than using a hub. Just curious, what are you connecting your GB ethernet port to now?
Administrator Avid Pro Audio Community |
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:<HR>Originally posted by Digidesign:
I don't know that any add-on ethernet cards have ever been tested with Control 24, much less endorsed.<HR></BLOCKQUOTE> Now I consider that very strange. More so because the following has been taken directly out of the C24 manual: "Optimal performance, however, can be obtained by use of an Ethernet card dedicated to Control 24 communications." I'm sure someone at Digidesign with authority included that in the manual? And it should have been tested. How does a multi-site ProTools+C24 facility operate. More so if this facility wants to maintain Gigabit Ethernet connectivity throught the facility for file transfer & networking? If it was just ProTools + the PowerMac G4, each of the post rooms would have one Gigabit Ethernet network point available for connecting the PowerMac to it. All these points would be wired to a central server room which would house a Mac server connected to a Gigabit Switch. Now, the only way then for these rooms to use their C24 units would have to be via a standard 10BaseT Ethernet card. Unless they wish to burn their pockets getting a 2 or 4 port Gigabit switch for each of their rooms, because the aim here would be to retain the GigabitEthernet speeds for file transfers. How can something this important not have been tested for ensuring smooth operation for multi-site facilities? Especially since we all know how badly ProTools behaves with regards to other cards and PCI bandwidth/traffic/bus master, etc..... |
Bump
Fair enough, like I said I wasn't personally aware of specific testing or recommendations, but the manual does seem to indicate otherwise. I've asked the product manager and ETS for clarification.
Fair enough, like I said I wasn't personally aware of specific testing or recommendations, but the manual does seem to indicate otherwise. I've asked the product manager and ETS for clarification.<HR></BLOCKQUOTE> Bump |
2nd Ethernet Card | Tomio Broman | ICON & C|24 | 3 | 10-12-2005 12:25 PM |
Ethernet Card | Brian Porick | Pro Tools TDM Systems (Mac) | 2 | 08-21-2003 03:07 PM |
Ethernet card issues - help? | pk_hat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 07-04-2002 08:15 AM |
BNC Ethernet card for G4? | bigfrog | General Discussion | 6 | 03-22-2001 05:05 PM |
Ethernet card : Yeh or Nay? | agentd | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 12-01-2000 07:43 PM |
