Old 09-27-2022, 02:02 PM
Audiodemolition Audiodemolition is offline
Default High Sierra will not see HD NATIVE TB
Sorry for the old gear, but this problem just arose.
This iMac: late 2013 i7 32GB Ram running 10.13.6 (high Sierra), Pro Tools 11.3.2. HD Driver ver 11.3.1 and 3.2 (tried both)
HD Native TB2 shows up in system profiler under TB devices, but the driver will not load even with the driver loader app provided through the KB.
I have exhausted all of the solutions on the KB
Can't figure it out. The only thing I haven't done is a fresh OS install, is that the next step?
Old 09-28-2022, 09:49 AM
jeff markham's Avatar
jeff markham jeff markham is offline
Default Re: High Sierra will not see HD NATIVE TB
What version of the HD driver are you using?
Wasn't there a work around you had to do to
disabling SIP .. running a command and then re-enabling
SIP?
something like: (from a Terminal window).
sudo kextload /Library/Extensions/DigiDal.kext
That was the workaround for a while on one of the older HD drivers.
Without that, the kernel extension wouldn't get loaded and the driver wouldn't work right.
MAC PRO High Sierra & PTHD 2018 can't recognized PCIe Native card Sutee Sangsareechon Pro Tools 2018 1 05-11-2019 04:48 PM
Video Card - Mac Pro High Sierra & Native Siegfried Meier Pro Tools HDX & HD Native Systems (Mac) 46 02-03-2019 02:26 PM
Question: Sierra or High Sierra for PTHD 2018.3? johnnyv Pro Tools 2018 25 03-18-2018 08:30 PM
PT 12.8.3 High Sierra 10.13.3 RCN Pro Tools 12 12 03-06-2018 03:18 PM
High Sierra reichman Post - Surround - Video 4 01-04-2018 01:56 PM
