Old 12-14-2005, 10:10 AM
bluesguy bluesguy is offline
Default Using Midi inputs and outputs??
Hi!~!~
This has been an ongoing thing but I am still trying to figure it out! I am using an Alesis Drum Module. I am triggering an accoustic drum set. I have midi cables hooked to the protools unit and I have one audio track with two cables coming out of the regular ports of the alesis to the protools channel one and two so I can monitor the sound. Then I have one midi track. I know I have to set the input of the midi track to All according to digedesign tech. But the output I am not sure about. There is nothing listed that says "alesis" or anything. Its just "channel 1", "channel 2" " ect. Is there something I need to do within protools to input the alesis or?? ANy help is appreciated!! Thanx!!
bluesguy
Old 12-15-2005, 05:59 PM
Default Re: Using Midi inputs and outputs??
When you are recording midi, its best to leave the midi track output set to some unused device or channel. When you want the midi track to drive the Alesis unit, probably set the track to midi out channel 10 which is the default for drum machines. (unless yours has been set to another channel-check the utility or midi menus if channel 10 does not work for you).
Inputs and Outputs PUMASALAD macOS 2 04-28-2011 03:47 AM
Absent MIDI signal on playback!! (checked inputs/outputs..) bquarrie Pro Tools M-Powered (Win) 5 05-02-2007 07:41 AM
001 midi inputs/outputs dont work anymore? El CaCa 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-10-2004 10:19 PM
Confused about MIDI inputs and outputs JDnSTL 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 11-18-2003 09:35 PM
how many inputs and outputs taiazeez Pro Tools TDM Systems (Mac) 0 01-28-2002 03:00 PM
