Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Carbon
Old 08-24-2021, 10:40 PM
Jaz64111 Jaz64111 is offline
Default Carbon and C24 I/O
Hello! I currently have an HD3 setup with a 192 (analog). I am looking to purchase Carbon. Can I just swap out the 192 with the Carbon (DB25 in and DB25 out) and keep the same configuration on the c24? My main concern is with the outs on the carbon because stereo outs are 1 and 3 with the c24.
Is anyone currently using Carbon with a c24? Help before I blow a ton of money
Old 08-25-2021, 08:01 AM
Kyle Splittgerber's Avatar
Kyle Splittgerber Kyle Splittgerber is offline
Default Re: Carbon and C24 I/O
Hello,
To confirm, you're using the (newer) C24 not Control 24, correct?
Yes, you can do this with C24. You'll want to connect Line Out 1-8 (DB25) on Carbon to Pro Tools In (DB25) on C24. Then, make sure your C24 5.1 path in I/O Setup is assigned to Line Out 1-6 and C24 Cue is assigned to 7-8 (if you used it). In Hardware Setup, ensure that 'Main' is unchecked. Attached are some screenshots for reference.
Kyle Splittgerber
Senior Principal Product Designer
Berkeley, CA
Carbon and Mac Pro 5,1 compatibility JayRay Pro Tools | Carbon 29 01-02-2024 06:41 AM
FS: Protools Carbon Technog0d Buy & Sell 2 05-10-2021 10:25 AM
Carbon and Mac M1 / Big Sur and other ?’s darkwavo Pro Tools | Carbon 31 05-01-2021 12:57 PM
Carbon with anything other than 10.15.7? Matt Hepworth Pro Tools | Carbon 12 01-08-2021 07:14 AM
