Old 05-21-2007, 10:18 AM
Jim Casey Jim Casey is offline
Default CROSSFADES, CROSSFADES, CROSSFADES, CROSSFADES
Ok guys, I am still beside myself. Do you have any IDEA why I can select a region for a crossfade sometimes and not others, in some areas and not in others?????
Any help will be appreciated.
Casey
You can hear what I'm doing at:
http://www.reverbnation.com/jimcasey
Old 05-21-2007, 10:29 AM
DigiTechSupt's Avatar
Default Re: CROSSFADES, CROSSFADES, CROSSFADES, CROSSFADES
To do a crossfade, you need to have enough region outside the region boundaries to crossfade over.
Maybe you should give us a scenario, so that we can determine where the problem may be if it's not the above...
Avid Audio Tech Support
Support FAQ
Old 05-21-2007, 10:31 AM
Str8Klownin Str8Klownin is offline
make sure the regoins overlap. also check and see if theres a fade already on the end of one region.
Old 05-21-2007, 10:35 AM
I figured that and I tried across the boundaries in slip mode and two beats in the grid. I will tinker with it again tonight in case I am brain farting and post back at you with a more detailed analysis.
Thanks for responding.
Casey
Old 05-21-2007, 10:37 AM
Thanks Str8. I am going to do more needling tonight. It was driving me crazy last night as I was trying to crossfade pops out of a mix. I could do some of them and not others at all.
Casey
Old 05-21-2007, 11:08 AM
JMS40 JMS40 is offline
Keep in mind, clicks/pops at edits usually have to to with chopping somewhere other than "zero crossing" points.
When you go to perform an edit, zoom in to the sample level and find a spot where the waveform crosses the center line.
If you pay attention to cutting at zero crossings, crossfades will be unnecessary.
Always avoid chopping on a peak portion of the waveform when possible.
See Avoiding Clicks and Pops page 343 of the 7.3 Reference Guide.
Old 05-21-2007, 11:33 AM
Yeah, I hate the extremem surgeries, can't avoid them sometimes. I spent a good time reading the reference this weekend and still had problems with crossfades. I was doing just fine fading out the pops on the end of chop edits and then all of a sudden I can't do it where I want to anymore. I might have killed that brain cell, or I have some kind of configuration issue or something. I am going to study it some more and write down spefics.
Thanks for the response and input.
Casey
Old 05-21-2007, 04:34 PM
Hey there. I went home today for two hours and I realized that, since I removed all the pops off of one of my guitar tracks, I have not been able to do a single crossfade.
I tried all over the tracks today and NOT a single one would take.
So, if I uninstall the software and reinstall 7.3.cs2 will I need to find my code? Is this a solution?
Casey
Old 05-21-2007, 06:48 PM
jackp jackp is offline
Hey jim I 've had some pops and spikes beforeon tracks. select I just zoom in on the wave, and pencil it out, with pencil tool
Mac Pro 8 core Protools 10 HD 4 Accel PCI with Magma, C/24 with 2 192 I/O
Isochrone clock
Old 05-21-2007, 06:49 PM
Hey jim I 've had some pops and spikes before on tracks. I just zoom in on the wave, and pencil it out, with pencil tool
Isochrone clock
Help me with crossfades! HastyRichtardo Pro Tools M-Powered (Win) 3 04-26-2010 07:51 PM
PT crossfades? buckaroo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-30-2008 12:46 PM
Crossfades in LE 6.9 trackster 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-27-2006 08:25 AM
Crossfades? Gary Fitz Post - Surround - Video 7 11-11-2005 01:12 AM
Crossfades stut5 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 02-24-2002 03:23 PM
