Old 10-11-2008, 01:33 PM
crizdee's Avatar
crizdee crizdee is offline
Default cannot import second video file! different frame rate message.
I'm trying to import several video files into a session and as soon as i try to import a second file is says "can't import as the frame rate is different from the video currently in the session" but all the videos are identical? same frame rate etc!
It looks like PT might be altering the frame rate when it imports the first video file! as it shows 2.76fps on the video track
everything is set to 29.97 fps and the videos are recorded at the same!
Any info appreciated
Chris
Producer, Engineer,
www.ukmastering.com
Old 10-11-2008, 01:47 PM
jimlongo's Avatar
jimlongo jimlongo is offline
Default Re: cannot import second video file! different frame rate message.
Command-J in QuickTime and let us know the codec and framerate.
noise | jimlongo
Old 10-14-2008, 04:11 AM
crizdee's Avatar
Can't see anywhere where it displays the frame rate? all i can see is format which is animation and stuff like start time/time code start etc.
Everey video i try to import seems to be a different frame rate? even one's recorded at the same time. i'm also trying with screen captures and the same problem!
How can i get a second video in to PT?
Chris
Producer, Engineer,
www.ukmastering.com
Old 10-14-2008, 06:31 AM
José Luis Díaz José Luis Díaz is offline
Hi crizdee,
Try cleaning ProTools's preferences with ProTools Prefs & Database Helper.
Old 10-14-2008, 07:17 AM
drenkrom drenkrom is offline
Quicktime and PT are often not on the same page as to the frame rate of video files. QT displays problems outputting to the correct frame rate when exporting to some codecs. You may ask for 29,97, for instance, but that doesn't mean you'll get it. On top of that, even When QT tells you two video files share the same frame rate, PT may disagree.
One sure-fire way of getting lots of files from different sources into sessions without a hitch has involved doing conversions and exports through Final Cut Pro. All files exported from FCP have a solid, predictable frame rate. If you're going to DV, passing through a fixed-framerate format like DV Stream has also fixed this issue.
Through testing, I found the differing framerate problem cropped up even within a batch of files captured at the same time. Once those files were exported from the FCP timeline, though, all appeared in PT with identical framerates.
Pref/database trashing has never had any effect on this issue. Over here, at least...
Old 10-14-2008, 08:26 AM
jimlongo's Avatar
Originally Posted by crizdee View Post
Hi,Can't see anywhere where it displays the frame rate? all i can see is format which is animation and stuff like start time/time code start etc.
You need to right click in the information window to display additional parameters.
noise | jimlongo
Old 10-14-2008, 09:10 AM
DigiTechSupt's Avatar
There are a couple issues with QT and FCP that can cause frame rates to not be read properly by Pro Tools, for example:
http://duc.digidesign.com/showthread...&highlight=fcp
Re-exporting using the same settings for both movies will usually help and, if you have Compressor, I've seen reports that it's the most reliable for re-encoding.
Avid Audio Tech Support
Support FAQ
Frame Rate Conversion for video file in Pro Tools RuffinMedia Post - Surround - Video 5 01-20-2016 04:05 AM
Can't import video when frame rate not the same as the current one Rockman413 Pro Tools 10 2 11-08-2012 08:52 AM
Same video frame rate still won't import - too often anyway Farmer Dave Pro Tools TDM Systems (Mac) 3 07-23-2007 07:22 PM
QT 23.98 video frame rate... timecode rate? dopplah Post - Surround - Video 10 07-03-2007 05:28 PM
7.2 BUG - Video import w/different frame-rate Charles Deenen Pro Tools TDM Systems (Mac) 4 08-08-2006 01:23 PM
