Old 08-04-2006, 02:53 PM
Charles Deenen Charles Deenen is offline
Default 7.2 BUG-Import (see error message) +region bin bug
(1)
Upon trying to import a music session from a contractor (which opens fine in protools by itself) into 7.2, I get the following error message:
assertion in /volumes/development/vbvd/AlturaPorts/PT4_app/MacBuild/../PtSess/PsSess_converter_5_1.cpp", line 990
(2)
Symptom: Protools gets confused about what file-name a file has
To reproduce:
- set bin to sort by date Modified
- Create or import a few files named 'Blah' (i.e. blah 1, blah 2 etc.)
- do a search for "BLAH" (make sure you have some files named blah1, blah2 etc.)
- record a new stereo or 5.1 file in protools
- name it 'blah 100'
now, notice that the newly named file PLUS the previous un-named file are in the region bin, and both get selected when you select the 'blah 100' region
- another search for 'blah' make that file go away.
Pretty damn annoying when you try to export files after a record.
-charles d
Old 08-05-2006, 07:31 AM
Default Re: 7.2 BUG-Import (see error message) +region bin
So after a bit more investigation, turns out that this sessions also won't load (sorry, I thought it did). So, this just changes the bug
Instead of being able to load the session and it gracefully bowing out, I got the above error-message.
-cd
Old 08-07-2006, 12:47 PM
Halstein Halstein is offline
Default Re: 7.2 BUG-Import (see error message) +region bin bug
Got almost the same error when trying to save or quit after installing 7.2. Error message that started as yours, but ended up with line 164. Found the solution on the answerbase (and that had nothing to do spesific to the 7.2 update!) - you have to trash all your volume databases!! Remember that all your active drives (after using PT) got a "Digidesign Databases" folder. Trash the content in each of those folders!
Since the error refers to a volume fault, I just guess that this solution could work for you as well. Good luck!
pthd9-pt11
imac 14,1 / imac 7,1 / macbook air 5,2 / self-built hackintosh with gigabyte z97x board + quad i7-4690
Old 08-08-2006, 08:49 AM
DUH ! didn't even think to look there. Will try. I must be sleepy, that's what I've been telling everybody to do for years, and now it's biting me in the *ss and I throw up my hands...
lol !
cheers
-cd
Old 08-08-2006, 01:49 PM
pat yacono pat yacono is offline
Hey Charles, there is a music contractor right here whose sessions will not generate that error. Lol... How have you been?
Error message when trying to import a video to a session cedlil Pro Tools 11 0 03-03-2014 09:11 AM
OMF Import Error Message, Line 162 pseradarian 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-05-2012 03:04 PM
Weird error message- can't separate region hobbobass 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-15-2010 06:00 AM
Cannot Record or import files - long error message 7vens 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-11-2007 02:23 AM
Weird error message on MIDI import Ray Lyon Pro Tools TDM Systems (Mac) 13 08-18-2005 08:20 AM
