Old 08-04-2005, 09:27 PM
Ray Lyon Ray Lyon is offline
Default Weird error message on MIDI import
When attempting to import multiple MIDI regions (from Stylus RMX) into the MIDI regions list I get the following message:
assertion in Sys_FileLoc.cpp, line 195
Nothing imports into the regions list. However, I can successfully import one file at a time. Any answers?
Thanks....
PT 6.7cs8
OS 10.3.7
Accel 3
G5 dual 2.0gz/2.5 GB RAM
Storcase dual FW800 w/ (4) 120GB Maxtor drives
Command|8
Mac Studio M1 Ultra, 64 GB, 1TB • Avid HDX • PT 2024.10.1 • OS 13.6.7 Ventura • Revive Audio modded Avid 192 interface • Sonnet xMac Studio/Echo 1 chassis • Avid Command|8 via Neyrinck V-Control Pro
Old 08-05-2005, 09:37 PM
Default Re: Weird error message on MIDI import *DELETED* *DELETED*
Post deleted by Ray Lyon
Old 08-08-2005, 08:11 PM
not exactly the most exciting problem in the world but I wld appreciate a response...
Old 08-09-2005, 08:25 AM
DigiTechSupt's Avatar
No, it's not an exciting problem and, unfortunately, there is very little info on what could cause this.
Does this ONLY happen with MIDI files from Stylus RMX or does it happen with others as well?
We're going to try to test this some time today to see if we get the same result.
Avid Audio Tech Support
Support FAQ
Old 08-09-2005, 09:06 AM
Ray - How, exactly, are you importing these MIDI files? Thru the MIDI regions bin or from "Import MIDI to Track" or some other method?
Support FAQ
Old 08-09-2005, 10:24 AM
PeterB PeterB is offline
Hi Ray & Digi Tech support
yes, I have exactly the same message. It occurs if I try to import more than one MIDI file at a time into the MIDI regions list e.g alt+apple key +i, or import MIDI from MIDI regions menu
Ray, I guess you are dragging the MIDI files from Stylus onto your desktop and then importing them. I do the same and I assume that you just have to import one at a time which is kind of a pain.... What do you say Digi? How about drag and drop in PT 7?
PB
TechnologyWorks Mastering
http://www.technologyworks.co.uk
Old 08-10-2005, 09:18 PM
I have only tried importing Stylus RMX files... virtually all of my MIDI work is done within PT except for this one item which must be imported.... as you know, the current version of PT does not support drag n drop.
Thanks for your response and I hope you come up with something... ! !
Old 08-10-2005, 09:22 PM
I drag the files from the appropriate Stylus RMX window onto a folder on the desktop labled "XXXX MIDI files" (where XXXX is the name of the tune)... then I place the folder into the file session folder for housekeeping purposes. I import from from the MIDI REGIONS BIN. I have also imported from the desktop and experienced the same problems.
(Sorry, I failed to add the capitalized info, as you requested, when I originally responded)
Old 08-10-2005, 09:26 PM
Hi Peter, yes a royal pain when you are constructing a drum track and have lots of files to import... I hope Digi can address this... best wishes...
Old 08-13-2005, 06:09 AM
Digi Techsupport, that was 8/9.. today is 8/13... any news?
As I edited my above post, I import from the Midi Regions Bin...
Thanks again for your help...
Weird error message- can't separate region hobbobass 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-15-2010 06:00 AM
Weird error message nitris Pro Tools M-Powered (Win) 1 12-17-2007 07:48 AM
Weird Error message with Logic/PT Hardware logandrum Pro Tools TDM Systems (Mac) 2 10-15-2005 02:07 PM
WEIRD ERROR MESSAGE powerjoe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-22-2004 03:51 PM
Weird error message keny Pro Tools TDM Systems (Mac) 1 05-17-2004 10:41 AM
