Old 08-31-2021, 10:42 AM
Focuret Focuret is offline
Default Is there a way to expand HD Omni to have 13 channels (7.2.4) for Dolby Atmos mixing?
Hey guys,
I have recently completed a 7.2.4 theater install in the room next to the stereo (2.1) studio. In the studio I'm running PT Ultimate with an HD Native Thunderbolt box and an HD Omni interface. The max inputs I need is one mic and one (maybe two?) guitars.
In the theater there's 13 total speakers for a 7.2.4 system powered by a Marantz amp and an Emotiva processor/receiver.
What would be the best cost effective way to leverage the HD Omni to have 13 channels for Atmos surround mixing? First time moving from stereo so I'm looking for advice and tips.
Thanks all
MacBook Pro Touch Bar (15-inch, 2016 2016), 2.9 GHz Intel Core i7, 16 GB 2133 MHz LPDDR3, Radeon Pro 460 4096 MB
Intel HD Graphics 530 1536 MB | macOS Monterey | Avid HD Native Thunderbolt | Avid HD Omni | Pro Tools Ultimate | Avid Artist Control | Avid Artist Mix
Avid Artist Transport | Genelec 8351b Monitors | Genelec 7360A Subwoofer x2 | Slate Digital VMS Virtual Microphone
Old 08-31-2021, 12:06 PM
nst7 nst7 is offline
Default Re: Is there a way to expand HD Omni to have 13 channels (7.2.4) for Dolby Atmos mixi
Unfortunately the Omni is maxed out at 8 inputs, 8 outputs. You could jerry rig the headphone cue output (9-10) for an additional 2, but that won't really help much.
The MTRX Studio would be a better choice for this type of thing.
Old 08-31-2021, 12:34 PM
I was going to go the Mtrx Studio route but wanted to know if there was a cheaper solution. Like maybe adding an old 192?
Old 08-31-2021, 01:35 PM
Cheesehead Cheesehead is offline
You can do it with an HD 8x8x8.
I was using it for 7.1.4 before I swapped it out for an MTRX Studio.
I suppose that means you could also use an old 192 the same way.
I used 8 AES and 4 analog outputs to get 7.1.4.
As long as your monitor controller allows you to split between digital and analogue inputs it will work.
Mac Pro 7,1 16 core, OSX 12.7.3, HD-Native TB, Trinnov MC, MTRX Studio, 2xRME ADA-4, Sync HD, AJA IO XT, Avid Dock, Avid S1, PT Control, Soundflow, PT 2023.12
Old 08-31-2021, 02:52 PM
Ok, it's probably a good time for me to stop being stupid and finally ask: what exactly is a monitor controller and why do I need it? I keep hearing about them and have seen the costs but I keep putting off understanding its exact use for what I'm trying to do. Time I asked. lol
Can you explain like I'm 5 what they are, what Dadmon is and what not?
Old 09-01-2021, 12:44 AM
Mark Ziebarth Mark Ziebarth is offline
A monitor controller controls the volume of your speakers aka monitors. If you’re monitoring stereo that’s easy and each and every monitor controller is capable of that. If you’re monitor path is wider like 5.1 or 7.2.4 the controller has to be able to control the complete path. DADman can do this if you’re using an MTRX interface. It can even be EuCon controlled via a hardware encoder provided on the Dock and other EuCon devices.
The Omni is the most limited interface of the professional Avid interfaces of the last twenty years. They allowed only eight in- and outputs simultaneously although the interface has more. A 192 has 16 in- and outputs simultaneously even though you have a lot more physical connections available. It was a philosophy of shortage like with the limited track count.
I hope this helps.
Best
Mark
Mac Pro 2010 3.66 GHz six Cores, HD Native, 192 I/O, Avid Dock, Artist Mix and Pro Tools Ultimate
Mac mini 2018 i5 64 GB RAM, RME Fireface, Pro Tools 2021, Euphonix MC Control
MacBook Air 2020 (M1) 16 GB RAM, 1 TB SSD, Zoom U-44 and Pro Tools Ultimate
Old 09-01-2021, 12:46 AM
JFreak's Avatar
JFreak JFreak is offline
... so how do you want to use it with 8 outputs?
Janne
Old 09-01-2021, 01:43 AM
That's what I was asking: would adding a Digi 192 or something to expand the number of outputs to 13 or above just easily work and be cheaper than getting a Mtrx Studio
Old 09-01-2021, 01:47 AM
JFreak's Avatar
192 has at lesst 8 analog outputs, unless it is the special 192digital version without anything analog
Janne
Old 09-01-2021, 01:48 AM
I hope this helps.
Best
Mark
This does indeed help and finally makes sense. Thank you! So it is looking like one way or the other the Mtrx Studio with a monitor controller is what I'll need. I have an Avid Artist Control and Mix plus the iPad app. Could one of those be used as a controller or would I need this: https://vintageking.com/digital-audi...erating-module
Dolby Atmos Spatial Audio Mixing on PC? EliLitwin Windows 3 11-27-2021 01:39 AM
HDX and Dolby Atmos ViciousLullabyz Pro Tools HDX & HD Native Systems (Mac) 7 08-13-2021 06:29 AM
Mixing in Surround and Dolby Atmos Sreejesh Tips & Tricks 6 02-25-2017 12:55 PM
Dolby Atmos subwoof Post - Surround - Video 3 09-11-2014 12:10 AM
Dolby Atmos peter5992 Post - Surround - Video 20 10-29-2012 01:51 PM
