Old 01-03-2001, 04:11 AM
ilnegro ilnegro is offline
Default AVOIDING POPS?
Is rhere a way to avoid pops when you do a punch in? When in destructive recording I can only mute the region where the pop occurs, and in non destructive I shift the regions boundaries til I find an acceptable situation. Both methods I don't like and find very annoying. Is ther an automatic fade in-fade out function or what?
Old 01-03-2001, 06:34 AM
search-one search-one is offline
Default Re: AVOIDING POPS?
just a tip: when i punch in i usually do it 1 bar before the artist acually messed up. then i'll lower the volume at the begining of the punch just to make sure there is no pop. then i use automation to smooth it out.. recently i have gotten very good with punch ins and i havent had to do this. i guess its just a lil practice.. its always good if you dont tell the artist where your gonna punch just let them flow and you be the engineer... hope this helps
Old 01-03-2001, 10:56 AM
lwilliam lwilliam is offline
I've often heard pops during the punch-in (mostly in destructive mode), but most of the time, they disappear on playback. If they don't, I just use a simple fade-in or crossfade. I believe only the TDM ProTools has "automatic" crossfades. PTLE has to be done manually. It's pretty quick and simple to do, however (especially compared to some of the competition).
LW
Larry
PT 2021; MacBookPro M1; 16GB; Spectrasonics; Native Instruments, Toontrack, Waves...too many plugins.
Avoiding duplicates when importing new AAF awe Post - Surround - Video 5 03-26-2012 03:03 PM
Avoiding Mbox Mic Pre? rhinostylee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 14 08-09-2007 09:29 AM
Avoiding scrolling mix window lobe Tips & Tricks 5 03-11-2005 08:39 AM
Please in help Avoiding latency with the 002r Tedmod 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-27-2003 06:51 PM
Avoiding Upgrade Problems ! Ian Greaves ProControl, Control|24, Command|8 0 02-28-2000 10:42 AM
