Old 06-01-2015, 01:32 PM
mrtomcat mrtomcat is offline
Default
does it connect/synch via the expansion port or via the external options?
PT Ultimate 2021.10
Nuendo 10.3
Wavelab Pro 11
UAD Satellite Octo Thunderbolt, UAD Quad Pcie
Apollo Twin Duo,
HDX Card,
2x Avid I/O Analog 16/16,
4x Artist Mix, Avid Dock, PT Control,
2019 Mac Pro 12 core, 48 gig Ram, running Big Sur,
lots of outboard gear
Old 06-01-2015, 01:45 PM
Craig F Craig F is offline
Default
the Expansion port on the HD I/O or the second port on the card/TB box
and the Loop Sync cables
Thank you,
Craig
Old 06-01-2015, 09:32 PM
JFreak's Avatar
JFreak JFreak is offline
Default
Yes, but if the 192 digital card in slot 3 is missing/broken, it cannot get sync to other boxes. If you use it standalone and only use analog i/o, you might not even notice you have a faulty digital card. Once you pair it with another interface... *doh*
Yes, the connection is done using expansion port and loop sync, but internally the 192 interface seems to require a working digital card for a handshake with other interfaces. New purple Avid HD interfaces do not have this requirement, thus fully analog 16 in 16 out box is able to sync.
Janne
Old 09-13-2021, 12:42 PM
1511 1511 is offline
Default Re: HD Analog I/0 16 built in optical ports
Hello, yes I was thinking the exact same thing as mrtomcat. I have an Avid HD I/O 16 x 16 with outputs going in to a Dangerous 2-bus+; was going to print with the AES digital out as described in the 2-bus+ manual; However, not possible without sacrificing a pair of interface outputs.
Mind if I ask what your final solution was?
Thanks,
Chas
Bus audio from Macbook built-in optical out to 002R using ADAT Megageoff 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-27-2011 06:22 AM
MacBook Pro built-in ports/external startup drive question Sequence8 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-06-2007 04:31 PM
Using built-in optical audio inputs DaveSullivan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-23-2006 10:34 AM
For any OO1 user using both optical ports (i/o) kindkind 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-15-2006 02:52 AM
Is there an Analog adapter for the Optical ports? Moot 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 09-06-2000 05:25 PM
