Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | MTRX & MTRX Studio
Old 07-25-2021, 10:16 PM
Goombot Goombot is offline
Default MTRX disconnects from DADMan
I see that there were some questions about this about a year ago and it seemed as if all the fixes were just to upgrade the firmware. I have two MTRX Studios' with HDX2 and the RedNet PCIeR card and I'm having an issue with the second MTRX disconnecting from DADMAn. Everything is current software wise. Dadman, ProTools, MTRX Firmware, Dante Controller, EuControl and Avid Artist. All current and everything is working except for the occasional disconnect. I am able to re-connect it by "Rebooting" my second unit under the Dante Controller Device Config page so maybe that is a clue. I'd like to know how to fix this. Both units are DHCP and everything is locked in Dante Controller.
Old 07-26-2021, 06:21 AM
creativecontrol's Avatar
Default Re: MTRX disconnects from DADMan
Static IP's, Manual IP's, IP range, how many networks?, Different subnets?
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 07-26-2021, 12:04 PM
Hey Jeff,
So we have the conversation going with clocking both MTRX Studio units.
https://duc.avid.com/showthread.php?...52#post2608852
I'm thinking solving that will solve this. So maybe I can through the first one then check this out after that is solved and see if I still have the same issue. Thanks
No Metering In Dadman with MTRX Studio Cheesehead Pro Tools | MTRX & MTRX Studio 18 03-04-2022 07:43 AM
MTRX DADman 5.4.4.2 & Firmware 2.3.2.1 Johnny Hulst Pro Tools | MTRX & MTRX Studio 3 08-13-2021 07:41 AM
DADman disconnects pkingduk Pro Tools HDX & HD Native Systems (Mac) 12 07-26-2020 05:22 AM
DADman MTRX profile question SomeOtherGuy Pro Tools | MTRX & MTRX Studio 18 07-20-2020 11:26 AM
Sum and Intercancel between MTRX DADman and S6 laki Avid S4/S6 1 12-27-2017 05:18 PM
