Old 07-03-2012, 02:26 AM
korkman korkman is offline
Default Neo Assertion
Hello -
I get the Neo Assertion error when trying to rename tracks in one session. I've trashed prefs and databases with trasher but to no avail. From earlier threads, I see that not unsimilar assertion problems (at least on macs) sometimes went away after switching to a new session disk or cleaning the old up. Can you verify that this is what it's about? Is a neo assertion of this type (line 1241 or something similar it says) generally a sign of disk problems?
Petter
ps. I'm on PT 10.2 with Win7 64 bit.
Old 07-03-2012, 10:41 AM
Craig F Craig F is offline
Default Re: Neo Assertion
what happens if you make a new session
Import everything
then try and rename the track(s)
Thank you,
Craig
Old 07-07-2012, 07:25 AM
mattt1 mattt1 is offline
I believe that Craig solution will work for you since I had this issue once and I solved it by this way..
Cohiba Siglo 6
Old 07-07-2012, 07:35 AM
The golfer The golfer is offline
Also when naming tracks do not use illegal caracters.
Serge Hamel
Mixer / Sound Designer
http://www.netpostproduction.com
http://immersivesoundvr.com/
Neo assertion rcutz macOS 2 05-06-2016 12:00 PM
neo assertion errors help rboos4 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 15 07-29-2008 09:02 AM
Neo Assertion Error Reckless Erik Pro Tools TDM Systems (Mac) 11 03-13-2008 11:12 AM
Neo assertion error ChrisBat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-07-2007 06:28 PM
Assertion Help dpetro17 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-22-2006 01:45 PM
