Old 04-25-2005, 05:58 PM
powerjoe powerjoe is offline
Default Click gets \"Quiet\" when recording commences..
I have not had this problem before. However,
I am using the "Wait for note" function when recording Midi in 6.9. Prior to hitting the trigger to commence recording, the click track is as loud as I need it. But, when I hit that first note, the click gets "quiet" even though I am maintaining the same fader level and I am using the Off function for that fader. ("off" as opposed to "read", "write..etc..).
As Jerry Seinfeld might ask: "What's up with that?"
Thanks !
Joel
Joel DuBay
Ready Acoustics LLC
Bass Traps and Acoustic Panels
www.readyacoustics.com
Old 04-25-2005, 06:03 PM
macr0w macr0w is offline
Default Re: Click gets \"Quiet\" when recording commences..
I have no idea.????
Intel I7 920
Asus P6T
Digi 002R.
Command/8
PTLE 7.1 MPT
www.clearspotrecording.com
Old 04-25-2005, 07:06 PM
bryanbassett bryanbassett is offline
I was thinking maybe some volume automation was kicking in ..but if you are not in read..?? I don't know. Is a MIDI control change possibly hitting that track?
bb
Macbook Pro Intel dual 2.4 OSX 10.7.5 Lion PT 9.0.6 Mbox Mini / 003R
MAC G5 PPC OSX 10.4.9 / PT 7.3 HD2 - I/O 192 /Control 24
DELL Dual Core, MBOX/003R PT 8 WIN XP
Old 04-25-2005, 08:00 PM
BIG D BIG D is offline
are you using the Clik plugin or a MIDI device for the click?
Big D
INTEL QUAD XEON
INTEL S5000XVN serverboard
4 gig Fully Buffered Ram (About to add more)
3 x WD500gig SATA, 1 x WD1T32mb SATA cache Green
NVIDIA Geforce 7300le,
Command 8,HD2,192,Massive Pack 4
Windows 7 64 bit PTHD 9
Old 04-27-2005, 10:39 AM
I'm using the click plug in. Not a midi device or trigger.
I just cannot figure it out. It is terribly annoying. I even added an eq plugin on that click track, and it gets quiet-er too.
Any other suggestions?
Thanks everyone!
Joel DuBay
Ready Acoustics LLC
Old 04-27-2005, 10:56 AM
Cliffy_Boy's Avatar
Cliffy_Boy Cliffy_Boy is offline
You have to setup the click for reocrding and playback. There are different options for when you want to hear the click. It also may be a case of not selecting the right monitoring. Try rec enabling the midi click track.
of couse Powerjoe, you may lose a bit on the Davec and have to start a new 30 page thread with Matt all over again.
Cliff Stendel
-iMac 5K 32g
-PT12. HDX
-HD I/O 8x8x8. -HD Omni -Avid S3
-API 2500 -API 5500 -UA 2-1176 -UA 2-610
-Neve 1073, Chandler LTD-1 -Eventide H8000FW -Lexicon PCM96
-Bricasti M7. -Joe Meek channel.
-Waves Mercury, Flux all, Softube All, Plugin Alliance all, McDSP all, Sonnox All, MH production, Wave Arts,a bunch more
-Moog Voyager XL, Nord Piano, Hartmann Neuron, ARP Axxe, Gibson Les Paul, Mesa Boogie Roadster, Kemper, Taylor T5 and T5-12
Old 04-27-2005, 02:34 PM
.... cliffy, always dripping with jealousy.....
My good man, I am not using a Midi click, I am using the click plug in. Now, what was that?
Joel DuBay
Ready Acoustics LLC
Old 04-27-2005, 02:57 PM
Email me your session.. I want to see how you have everything routed.. sounds like you're double monitoring until you enter record.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 04-27-2005, 05:56 PM
The Weed's Avatar
The Weed The Weed is offline
Maybe he has the Record and Playback faders unlatched in Preferences? If that's the case, then it would be possible to have a lower volume when in record than when playing back.
Cheers,
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Quiet PCs (Recording in same room as PC) Advice? KD11520 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-10-2007 07:32 PM
Recording with click on PT6 Animal 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-05-2005 04:58 PM
How quiet is the Magma Quiet 4 slot Chassis? Walling1 Pro Tools TDM Systems (Mac) 3 07-15-2002 10:37 AM
recording to a click-anyone? AnalogTree 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 11-24-2000 03:13 PM
recording with a click ve ge 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-10-2000 03:26 PM
