If I wanna set the pan for say -12.3, is there a way that I can type in that value instead of dragging with my mouse back and forth til I finally hit that exact number? It's quite frustrating.
You can't set the pan to a tenth of a value. If you want to set the level to a tenth of a dB, hold the command key while moving the fader. This will move the fader in .1dB increments.
Open the fader window (clicking the mini fader below the mixer channel input)
Double click the relevant field and then simply enter the required numeric value ( with +/- for pan direction). |
True and the same method will allow you to set pan in whole number increments. For Windows use the Control key instead.
Help Us Help You Chris __________________________________________________ Focusrite Liquid Saffire 56 FocusritePro 40 (2) TCE Studio Konnekt 48 Rascal Audio Tonebuss 24 Slate Digital VRS8 Gigabyte GA-Z170-HD3P i7 6700K 4.1 GHz 32GB DDR4 macOS 10.15.7 UAD-2 Octo Core PCIe Pro Tools HD 2022.5 |
Volume Automation: Exact Values | carterisgod41 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-10-2012 06:08 PM |
Tempo change causing midi volume to change plugin output | tgrfox | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-05-2011 01:08 PM |
Change Volume Setting | JustGotPaid | Pro Tools M-Powered (Mac) | 1 | 06-19-2010 07:31 AM |
Why i'm i still getting volume change | vudoo | Virtual Instruments | 1 | 07-21-2009 01:25 AM |
Can't Change Volume! Please Help! | ajp | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-22-2004 05:45 AM |
