Old 02-08-2013, 11:03 AM
sb_stefan sb_stefan is offline
Default How come I can't change the volume in the mix window?
If I do some volume changes to a track in the edit window, how come I can't change the volume in the mix window when I play the song. The volume control just slides back if I drag it up or down.
Old 02-08-2013, 11:38 AM
sw rec sw rec is offline
Default Re: How come I can't change the volume in the mix window?
Because you have some automation written on the track. Change the view from waveform to volume, then either clear all the dots, or highlight the whole track and then change the volume.
Old 02-08-2013, 11:50 AM
Ok, thanks. How do I clear the dots?
Old 02-08-2013, 12:33 PM
highlight em and hit delete
Old 02-08-2013, 02:19 PM
Hit youtube and watch some videos on using automation in Pro Tools. Once you get your head around it, you'll love it
Old 02-08-2013, 03:15 PM
Mikey MTC Mikey MTC is offline
Or, if you absolutely don't want any automation in your project, you can just open the Automation Window and click on "suspend." But that will disable automation entirely and globally until you reinstate it.
OR
Select absolutely every track in your session for the entire duration of your session. Then from the Edit menu, in the "Clear" section, select "Clear All Automation" and that should remove all the dots from everywhere they might have gotten into.
Old 02-08-2013, 04:11 PM
After playing around with Pro Tools for a few hours I finally got my head around the whole automation thing, and yes, I love it! I have pans, volume changes, mutes and fades going on all over the place. When I play the song and watch the mix faders move around I just sit and smile.
Thanks for all the replies you guys!
Old 01-15-2020, 08:53 AM
hieronymous hieronymous is offline
I know this is a really old thread, but I wanted to express my gratitude to those who posted the answers here.
I have been using Pro Tools with the MBox since 2002 - upgraded to the MBox 2 Pro around 2008. I am 98% self-taught. Last night I dug up an old session from my original MBox days to try and remix. Every track had what looked like leftovers from crazy automation! I tried moving them out of the way but knew there had to be a better method. I don't even know what those dots are called, so couldn't look up in the manual. Finally, after some desperate Google-searching, I found this thread and was able to clear all the automation from all the tracks and start fresh! Figuring out how to do this was a real relief and being able to start remixing the track was a major rush! Thanks again!
2008 MacBook Pro v. 10.5.8
MBox2 Pro
ProTools LE 8.0.1
Old 01-15-2020, 09:19 AM
EGS's Avatar
EGS EGS is offline
Originally Posted by hieronymous View Post
... after some desperate Google-searching ...
Google and/or YouTube is often a quick way to learn new stuff.
Desktop: PT 2020.5 / Win11 / Intel 11th Gen i9 5.1GHz / 64Gb DDR4-3600 / Gigabyte Z590 Vision D / Focusrite LS56
Laptop: PT 2020.5 / Win10 / older HP ProBook with i7 quad / U-PHORIA UMC1820
Legacy (works!): PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI001
Click for audio/video demo
Old 01-28-2020, 05:19 PM
basslik's Avatar
basslik basslik is offline
This forum is priceless, and all the great folks here are tremendous, especially albee1952. I can always count on him ~ !
By the way albee1952. Are you still using the 003 I see ?.
I'm still rocking on my 003 console, it just works.
What is the farthest you can go on the 003 by the way ?
Considering I'm on a Mac Pro 5,1. / Mt. Lion / PT9
MAC PRO 2010 5,1 3.46hex 128ram - BIG SUR 11.2.3 - OPEN CORE 0.7.2 - PT 2021.3.1 / 003 CONSOLE / DIGIMAX FS / PCM90 2CHANNEL SPDIF
Tempo change causing midi volume to change plugin output tgrfox 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-05-2011 01:08 PM
Why i'm i still getting volume change vudoo Virtual Instruments 1 07-21-2009 01:25 AM
Tempo Change Window bug shadowbox Pro Tools TDM Systems (Mac) 0 05-10-2004 09:09 PM
Can You Change Playlists From Mix Window? tomhartman Pro Tools TDM Systems (Mac) 0 03-20-2004 03:58 PM
Can't Change Volume! Please Help! ajp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-22-2004 05:45 AM
