Old 08-16-2011, 08:42 AM
qwertyuiop qwertyuiop is offline
Default Pro Control main unit power not working faders move
Hi everyone,
I turned on the gear this morning and I got "ethernet cannot communicate with main unit please power cycle"... so this happens every now and then so I unplugged and replugged in the ethernet cable.
same error
power cycled the unit
same error
I repeated this a few times, and swapped out the power cable... no change..
Basically here's what's up. The main unit when power cycled, the faders will slide up and pop back down but no LEDS are lit up, the center section says nothing (doesn't say offline; welcome to pro control). Hitting utility does nothing. The additional Fader pack works fine.
Any and all advice would be much appreciated. Thanks so much.
Control 24 faders jumping/not working fix!! crizdee ICON & C|24 2 08-22-2021 09:50 AM
Pro Control Main Unit freaking out theothermm ProControl, Control|24, Command|8 1 06-27-2011 10:10 PM
Main unit of my D-control says "offline" corbittclam ICON & C|24 2 06-09-2011 12:56 PM
Main unit as Faderpack? Vedat ProControl, Control|24, Command|8 0 07-31-2009 11:25 PM
Main control unit fader problem jackie ProControl, Control|24, Command|8 4 10-31-2007 09:30 AM
