Old 07-20-2009, 07:04 PM
vudoo vudoo is offline
Default Why i'm i still getting volume change
I can't seem to figure out why Kontakt is still getting volume change message. I'm playing a Midi track out of PT 8 via rewire into Bidule ( my VST host ) where there's a Kontakt instrument instantiated. When i start playback the volume of Kontakt jumps to 127. I checked my midi track and there's is no volume change midi message whatsoever. Any idea ?? thanks
Old 07-21-2009, 01:25 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Why i'm i still getting volume change
Is it getting its midi volume from the level of the midi track in PT? try lowering the fader of the midi track in pt and see if that changes the level.
Chris
Producer, Engineer,
www.ukmastering.com
How come I can't change the volume in the mix window? sb_stefan Pro Tools 10 9 01-28-2020 05:19 PM
How do I pan or change the volume to an exact value? sb_stefan Pro Tools 10 3 02-15-2013 04:51 PM
Tempo change causing midi volume to change plugin output tgrfox 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-05-2011 01:08 PM
Monitor Volume doesn't change anything... charon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-13-2004 05:39 AM
Can't Change Volume! Please Help! ajp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-22-2004 05:45 AM
