Old 03-18-2013, 03:29 PM
Christian Christian is offline
Default Need gear advice bad? Pro Tools 10 & mixing brands of converters
Been out of the loop for the last few years on the new technology for running Pro Tools as it's updated. Still running a Digi001 on a Dual G4 with Panasonic AD96/DA96 converters.
So what I want to do is update to ProTools 10, get rid of my 001, keep my Panasonic Converters and add a Lynx Aurora 16 converter set & pick up a one/two-year old used G5.
What would I need to get the Panasonic & Lynx converters working together? Lynx AES or LT-HD
The Apogee Symphony set also comes to mind and if this would work better then the Lynx.
Do I need to purchase a ProTools Core card & accel cards also?
Any help is really appreciated.
Thank you
Old 03-21-2013, 02:53 PM
P,B,S P,B,S is offline
Default Re: Need gear advice bad? Pro Tools 10 & mixing brands of converters
I dont think PT 10 will run on a G5, I could be wrong but I think PT8 was last for that. , get a mac pro 5.1 or newer for future PT releases.
If you pan on using PT HD you do
Thank you[/QUOTE]
Need gear advice bad? Pro Tools 10 & mixing brands of converters Christian Pro Tools HDX & HD Native Systems (Mac) 6 03-18-2013 09:56 PM
Mixing converter brands midnightsun Pro Tools TDM Systems (Mac) 1 05-12-2008 11:31 AM
New to mixing in Pro Tools...Need advice..PLEASE! jpaz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-06-2007 09:39 AM
Mixing RAM brands - same specs SixChurchStreet 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-19-2007 08:48 AM
Mixing in Pro-Tools EQ plug-in advice? Nimrod Tips & Tricks 9 07-09-2001 12:29 AM
