Old 05-05-2010, 05:37 PM
Shan B Shan B is offline
Default Recording with instrument tracks and audio tracks
I started a new session where I recorded some horn sounds into an audio track from an external keyboard, then loaded a plugin on a new instrument track to add some drums. After that I created a second audio track to record a new sound from the same keyboard.
But when I record arm the second audio track and play the keyboard both the plugin on the instrument track and the keyboard on the audio track sound. Unless I set the MIDI output on the instrument track to none. Also, I can't hear the keyboard on the audio track during playback.
Oddly enough, it will record the audio from the keyboard even though I can't hear it, and I can hear the recorded audio during play back.
Any suggestions on how to fix this would be greatly appreciated.
Old 05-05-2010, 06:28 PM
tlennon tlennon is offline
Default Re: Recording with instrument tracks and audio tracks
Deselect the instrument track so that it wont play when recording audio or set Midi Midi output to none as you did. Check your audio input monitoring in the Track menu option. Do yourself a favor and read the manual.
Terrence Lennon
Ivory Key Productions
Old 05-01-2011, 02:22 PM
mbradley44 mbradley44 is offline
dont even bother answeing the question if u tell him to read the manual
Recording multiple Midi (instrument tracks) Bookerv12 Getting Started 9 02-08-2014 06:17 AM
Transposing vst instrument tracks before recording THASAINT45 Pro Tools 10 1 10-15-2012 04:38 PM
MIDI tracks are recording an unwanted instrument sound Jen H MIDI 1 10-05-2012 06:39 PM
Applying Instrument Tracks to Reg. Audio Tracks d00m1001 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 03-13-2009 08:55 PM
Recording Simult Instrument Tracks. Is this possible? memphis81 Pro Tools M-Powered (Win) 1 03-29-2007 02:43 AM
