#21
Re: MTRX Studio Mic In's / Dolby Audio Bridge...
Yeah, I tried PTAB 32 and 64, same issue.
https://lukehoward.com/ |
#22
Even with PTAB, there's no reason to not use DAB if you are funneling from Pro Tools -> DAPS. It's all set up and ready to go. Use PTAB to get back to Pro Tools and or to route re-renders into Logic for Apple Spatial monitoring on Airpods, etc.
Jeff |
#23
Jeff, would you mind giving some concrete routing to achieve this? Is it possible to listen to speakers and logic (AirPods) at the same time?
___ Mac Studio Ultra, OS 13.6.5 MTRX Studio, PT Ultimate 2023.12.1, HDX1, Sync HD, BM Decklink Extreme 4K, Genelec's 9.1.4, Dolby Atmos Renderer, Avid Dock, S1, SoundFlow, Streamdeck |
#25
Scott Gatteño |
#26
Both Pro Tools Audio Bridge and Dolby Audio Bridge include an internal synching mechanism which will automatically follow the clock speed of the main playback engine.
best, Jeff |
#27
Thanks for answering all these questions! It's definitely helping me wrap my head around these new features.
Scott Gatteño |
#28
Thank you Jeff, this looks like good solution for Laptop set up. I was wondering if there is a way to have renderer connected as usual to the set of speakers and also have a logic at the same time with AirPods Pro?
#29
This described setup is exactly that. Add a 12 channel path (7.1 + 4.0 for heights) in the Input tab of IO setup which leverages AUX IO via PTAB. Output via DigiLink paths to MTRX ST as normal. You can then monitor 7.1.4 speakers, Dolby binaural and Apple Spatial all at once.
Jeff |
#30
Thanx Jeff, I am still not very clear about this new way of routing signals.
_ I have 9.1.4 set up, does this mean that if I want to monitor thru Logic (as well) I need to send the re-rendered 7.1.4 audio to Logic? _Normally I have HDX selected in the output of the renderer while DAB is main playback engine. Like this I can open only the renderer and listen to the atmos masters without Pro Tools running, In the way you suggest, will I be able to do it like this as well? Or is PTAB only available while Pro Tools is running? Looks to me that I need to make some changes in the dadman? thanks a lot, btw, I am very pleased with the Aux I/O
Dolby Renderer sync issue with HDX/MTRX Studio | remainanon | Pro Tools | MTRX & MTRX Studio | 7 | 05-24-2022 02:32 PM |
MTRX Studio HDX and Dolby Atmos Production Suite | Goombot | Pro Tools | MTRX & MTRX Studio | 64 | 09-30-2021 01:02 AM |
What brings Dolby Audio Bridge to HDX users? | nedd | Post - Surround - Video | 29 | 01-03-2020 03:24 PM |
Dolby Audio Bridge and AVB | RSLAMBERT | Avid S1, S3, Dock and Control App | 0 | 11-03-2019 01:46 PM |
Dolby Media Producer Suite v2, Decoder, How to get audio to my SPK w HDX and MTRX rig | bsteeve | Post - Surround - Video | 3 | 08-16-2019 06:19 AM |
