Hi guys,
Currently having a major issue where I get the AAE #-9173 (Pro Tools ran out of CPU power) message on start up. Yesterday everything was working fine but today I'm constantly getting this error code even on start up with a blank session!? How can it run out of cpu power when there's not even a single plug-in? Currently have tried restarting the computer, changing USB ports for the interface, updated anything related to pro tools, changed buffering size and cache size all to no avail. Currently running pro tools 12.7.1 with the CPU running at about 40% load. Have loaded past sessions and even blank sessions and am unable to do anything without the error code. Any help would be greatly appreciated. CPU: Intel 15-4690K @ 3.50GHZ Interface: Focusrite Scarlett 18i20 Pro tools: 12.7.1 Memory: 8GB DDR3 OS: Windows 7 |
Is it happening on Application startup, or session launch?
Pro Tools 2022.10|Perpetual • MTRX Studio • HDX1 • Sync-X • S3 • Dock • Mac Mini 2018 - 3.2GHz i7 6-core macOS 11.6 • RAM 64GB DDR4 GPU AMD 6900XT 16GB • Monitor LG 32UL950-W |
When I open a session and click play I instantly get the error message, even if its a blank session. When I unplug the scarlett 18i20 and just run the session straight from the computer it works but as soon as I set the Scarlett to the playback engine I instantly get the error code
The fact that the error disappears when you unplug the Scarlett indicates that the problem is there. 9173 is a buffer underrun error. Try trashing your preferences. If that makes no difference, check that you have the latest Focusrite driver and re-install it.
Dell Precision 490 Workstation, dual 4 core 5355 Xeon, 16gb Samsung DDR2 ECC Ram - Windows 7 Ultimate - Nvidia GTX 650 - 3 x Internal WD Blacks - PT 2018.3 - Digi 002R - Original Mackie HUI - JBL Monitoring. Dell XPS 8700 i7-4790 - 24gb RAM - Windows 10 - Nvidia GTX 1060 6GB with Studio driver 516.94 - 2 x Internal Samsung 860 EVO SSDs, and MSATA card - Davinci Resolve Studio 18.1.2 - Blackmagic Speed Editor - MK1 Presonus Faderport - Canon C100 mk2 - Atomos Ninja 2 - Zoom H2n |
Thats what I was thinking. The interface does work in ableton live though... Have deleted the pref and almost every other troubleshooting option. Even reinstalled everything from drivers to pro tools. Hard to understand what could be going wrong when it seems the interface is causing the error 9173 (cpu issue).
Quite a few people seem to have problems with Focusrite interfaces and drivers.
Tell us more about your hard drive configuration....
Running pro tools off a SSD. Have tried loading sessions off the same SSD, another SSD, HDD, and portable HDD. Still same issue. Going to try a friends scarlett 18i20 and see if i get the same issue
I had this problem and it was pissing me off all day. The fix for me was to update the drivers for my USB interface. Mine is a PreSonus AudioBox 44VSL.
I have/had this issue. It ticks me off but it happens very rarely and shutting everything off and restarting computer makes it run for days with no issues.
Sometimes I have to restart twice. I have a Presonus Studio 192 and a DP88 and an old Profire 2626 on mine. I HAVE noticed that if I have my Roland SPD-SX hooked up via USB it almost always causes a problem. Disconnect that and it is rare but still happens on occasion. |
AAE error -9173 on PT 12.4 | marcnyc | Pro Tools 12 | 2 | 06-24-2016 04:27 PM |
-9173 error in PT 12 | ArKay99 | Pro Tools 12 | 10 | 06-11-2016 02:41 AM |
Error -9173 | music.m | Pro Tools 11 | 1 | 03-19-2015 10:42 AM |
PT 11 Clearly Not An AAE 9173 Error | rgconrad1 | Pro Tools 11 | 3 | 09-30-2014 12:56 AM |
