Old 02-25-2011, 09:40 AM
Porky Porky is offline
Default Izotope RX2 thru PT
Does anyone know of a way to route RX2 (stand alone) through ProTools without going directly out of the sound card (which can be noisy)? If i try to use the ASIO setting in the RX2 preferences it says "in use by another application". I don't like using the AudioSuite version because there are parameters that are only available in the standalone version.
Any solutions?
Dave
CBS TV Distribution/On-Air
PT 2019.6.0
S3
Old 02-25-2011, 10:35 AM
FlorianE FlorianE is offline
Default Re: Izotope RX2 thru PT
On the Mac:
- set 'Digital' as standard Output in Audio/MIDI setup
- connect optical/Out on Mac to optical/In on 002
- in ProTools I/O, make an SP/DIF Input
- in the Session, make an Aux with this input, route it to monitoring
On PC:
if the soundcard has an SP/DIF out , the same setup is feasible
Cheers
Florian
Old 02-25-2011, 10:48 AM
Great solution, thanks. I will use that on my mac, but my work computer is an HP8200 with no optical output on the soundcard.
Dave
PT 2019.6.0
S3
HTML code is On
Izotope and 9.0.5 Mitch Griffin Pro Tools 9 89 01-25-2014 06:54 AM
iZotope RX 2 tom_lowe Post - Surround - Video 21 10-09-2010 02:00 PM
izotope spidera 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-13-2004 10:31 AM
