Old 10-13-2010, 10:04 AM
marty lester marty lester is offline
Default export midi
hey folks...
baffled. i'm exporting a PT session as an OMF, and the midi doesn't xfer. fine. i export the midi tracks and export a midi file and the only thing that happens when i re-import that midi data into a new session is i get the memory location markers.
what am i doing wrong? the tracks are highlighted, as is the whole time-line.
PT version 7.4 HD/3
Mac OS 10.4.11
2 x 2.66 dual core xeon
5 GB memory
thanks,
marty.
Old 10-13-2010, 10:16 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: export midi
Originally Posted by marty lester View Post
hey folks...
PT version 7.4 HD/3
Mac OS 10.4.11
5 GB memory
thanks,
marty.
OMF only does audio not midi
You'll need to do a midi file as well as OMF. the midifile does the location markers as well as the midi and the tempo map!!!!
Chris
Producer, Engineer,
www.ukmastering.com
Old 10-13-2010, 01:55 PM
Originally Posted by crizdee View Post
Chris
thanks for the reply...yeah, i have done a separate midi file yet no actual midi tracks come along in the export. very odd.
Old 10-14-2010, 07:34 PM
ok...pilot error of course. been so long since i've exported midi. turns out
it was either because the midi track was muted, or the track was in notes mode rather than regions mode...but more than likely because i had the track muted.
hope this helps someone as forgetful as i,
marty.
Old 10-14-2010, 10:04 PM
drBill drBill is offline
Hey Marty -
Yeah, must UNMUTE all tracks you want to transfer.
As you figured out, it's a 2 step process - OMF & MIDI for tempo map, etc.
Bill
Export MIDI Without General MIDI assignments grhufnagl 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-24-2009 10:12 AM
Export MIDI produces corrupted data. Unable to export MIDI ! Chris7514 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-01-2007 08:18 PM
Midi export Toontrack Pro Tools TDM Systems (Mac) 2 08-07-2006 11:13 PM
protools midi export to garageband midi? speky 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-23-2006 11:39 AM
Export MIDI ?? Virtual 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-30-2002 09:03 PM
