Old 03-12-2010, 04:59 PM
HDK_Ent HDK_Ent is offline
Default strange problem
ok, for some odd reason, i cannot access my add or remove programs, program from the control panel.
i click it, it pops up, nothing loads under currently installed programs.
it just says please wait while the list is being populated.
now i have quite a bit of stuff installed on here.
but not THAT much....
what im trying to do, is uninstall then reinstall my Zune software. cause its not functioning properly.
but. i cant uninstall it through the program folder, since it has no uninstaller, and i cant go through add or remove programs, cause its not loading...
DVERB Test 306
i7 920 2.66,
Gigabyte EX58-UD3R,
6 GB Corsair XMS3 Ram,
WD 500GB 7200 rpm HD,
WD 750GB 7200 rpm HD,
MBox 2 Mini, PT LE 8,
Axiom 49 Midi Controller,
Akai MPK 61 Midi Controller,
AKG C-414 Microphone.
Wish List: 2 Months.
Digi 003 BLA Mod,
MBP i5, 2.53 Ghz, 4GB of ram, 320GB internal, 500GB External Firewire, Waves Mercury,
Dverb Test - 156
"How you gon' do an 'Intro' to an 'Outro'?"
-Steezy on "Goodbye" By Spliit
Old 03-12-2010, 05:40 PM
Jenk2k Jenk2k is offline
Default Re: strange problem
Windows is corrupt. It's time to back up your stuff immediately and reinstall windows. (no I'm not joking)
It's only a matter of time before something more drastic than just add/remove programs getting hosed happens.
We don't have the user centricity. Until we understand context, which is way beyond presence — presence is the most trivial notion, just am I on this device or not; it doesn't say am I meeting with something, am I focused on writing something. [LIST][*]Bill Gates .NET Briefing Day Speech (24 July 2002)
Old 03-12-2010, 06:05 PM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
Yeah thatz def a OS/Comp problem much more than a PT prob...
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
Old 03-12-2010, 06:57 PM
Last time I had that issue, it was a trojan or virus and it took a lot of work(and cursing) to clean up the mess(actually it took reformatting and restoring from a drive image)
Old 03-13-2010, 02:20 AM
so should i back up? or make a clone image... reinstall and pull the clone off?
DVERB Test 306
i7 920 2.66,
Gigabyte EX58-UD3R,
Digi 003 BLA Mod,
Dverb Test - 156
Old 03-13-2010, 08:05 AM
Won't matter; it'd be the same either or so just whichever u choose...
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
Old 03-13-2010, 08:19 AM
MikeLip MikeLip is offline
Control Panel gone is a virus (99%). Backup data. Expect to be reformatting system drive.
Old 03-13-2010, 08:27 AM
necjamc necjamc is offline
I wouldn't clone if you may already have a virus. As it would probably get carried over, if in fact the clone worked. Usually this sort of thing knocks out all major windows functions eventually. Better to just back up you important data and do a complete reinstall. I have had this happen a few times.
And when you are back up and running Clone the drive right away.
Old 03-13-2010, 09:01 AM
Yes, for those watching with curiosity, the time to clone is when the system is freshly loaded, and then when you have had solid stability and performance for a month.
8.04 Strange Problem RBp Pro Tools M-Powered (Win) 2 07-21-2010 05:56 PM
strange problem help koka Pro Tools TDM Systems (Mac) 0 05-16-2008 02:57 PM
strange problem Tuur 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-14-2006 04:20 PM
Strange Problem... Zetajazz44 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 11-13-2005 10:08 PM
strange 001 problem Robocop 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-14-2003 03:39 PM
