Reduce clip volume
I'm wanting to reduce all the volume breakpoints in a clip by the same amount - I'm just not seeing how to do this. :-(
Windows 10 Home - 64bit - 8Gb Ram Intel Core i3-4130 3.40 GHz Focusrite Scarlett Solo with Pro Tools Studio and Melodyne Studio |
Re: Reduce clip volume
Go past the last volume node and lower the line. Or, use a Trim plug-in.
Hi Weed, I'm afraid I'm going to need a simple English answer
Aha!! Thanks Mr Weed, Trim plugin is exactly what I was looking for - I never knew it existed - duh!
No English here, this is Mac Avidspeak. Try this. Select the clip(s), hold down Shift+Control (Mac), and while holding them, type the up or down arrows on your keyboard to raise or lower the club gain. (The default is .5 dB per arrow click, but I increase my setting to 1.0 dBs.)
Sent from my iPhone using Tapatalk Pro |
On a clip with volume breakpoints, can also use the icon in bottom left corner. Raising or lowering that fader will raise or lower all breakpoints together.
___ >> me: nednednerB // ||main gig: editing audio voiceovers & testing software | 2nd gig: music software tutoring | hobby: electronic music // ||software: Sonoma 14.2 | PT Studio 2023.12 | Ableton Live 11 | iZotope RX, Ozone, Neutron | Arturia Pigments | Auto-Tune | Dubler2 // ||system: iMac (Retina 5K, 27", 2020) 10-Core-i9 | 128GB-DDR4 | 5700-XT-16GB | OWC Thunderbolt Hub and Thunderbolt 3 Dock // ||devices: RME Babyface Pro FS | Focusrite Clarett 2Pre | some AT mics | SM58 | Ableton Push 2 | Sennheiser HD 600 HP // Onkyo TX-8220 SR ||automation: SoundFlow | Stream Deck+ | Keyboard Maestro | SteerMouse | MacOS Shortcuts // |
It really depends if you're talking about clip gain or volume automation.
~Will |
For volume automation, just go past the last breakpoint and the volume edit tool(the sideways ]) will adjust the entire volume line up/down. And yes, the Trim tool can work, as can adjusting the output of the last plugin on a track(if it has an output control).
Volume issue when dragging in clip | alimakavelli | Getting Started | 8 | 03-08-2022 02:42 AM |
Has Clip List audition volume always been tied to Audiosuite audition volume? | leftalive | Windows | 3 | 06-15-2019 04:50 AM |
How to reduce volume of backing track? | 11R0 | Tips & Tricks | 3 | 09-16-2016 08:26 AM |
Converting Volume Automation to Clip Gain = Higher Volume! | EricWillhelm | Pro Tools 10 | 8 | 11-01-2011 11:12 AM |
Nipinpg down a short clip in volume | Peter Groom | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 10-25-2006 08:27 AM |
