  #21
Old 07-17-2022, 02:07 PM
Default Re: Macbook Pro for Pro Tools Ultimate
Yep Butterfly, so just check it carefully.
  #22
Old 07-17-2022, 06:23 PM
sean shannon's Avatar
sean shannon sean shannon is offline
I sure will, thanks for the heads up.
Check your mix in mono.
www.mixingtheband.com
  #23
Old 07-17-2022, 11:09 PM
GoButtonGuy GoButtonGuy is offline
We had/have some of those 15.1 MBP. Plenty capable machine. In most instances we're swapping them out for M1 MacBook Airs. Pro Tools is usually quite a bit behind supporting the current MacOS version. You won't have an issue with those size sessions.
What happens in Vegas, we make happen...
  #24
Old 07-22-2022, 07:10 PM
Update: The 2018 Macbook Pro deal fell through, so I got a 15" 2019 Macbook Pro with the i9 and 32GB RAM. I'll get it in a few days.
  #25
Old 07-28-2022, 02:02 PM
2019 i9 Macbook Pro arrived. Very speedy, brand new battery with 0 cycles. I'll be installing software over the new few days, but Harrison Mixbus runs fantastic.
  #26
Old 09-01-2022, 10:39 PM
I can confirm the 2019 Macbook Pro i9 w/ 32G RAM and Mojave runs Pro Tools Ultimate 2022.7 amazingly. I have 32 audio tracks with an Orion USB, 16 buses, plus master running on this session. There's the SSL Channel Strip 2 on every track, plus plugins on the buses and master, and HEAT, and I'm at less than 10% CPU.
I'm running SSL 360 app, Decibel wifi to my tablet for metering, and a Presonus Faderport 16, with an HDMI TV for a larger second screen, and it all runs very fast and smooth. I'm happy with the setup. Low buffer of 64 for tracking, 1024 for mixing.
I was considering picking up a chassis for my HDX card, but so far, I don't think I'll need it. Besides, to run the playback engine in HDX I assume would need a compatible interface, and this Orion does not have the AVID connections.
  #27
Old 09-02-2022, 12:03 AM
Yes HDX requires DigiLink IO connected to it.
Dumb question - Can I run PT Ultimate on a Macbook Pro? innerbooty Pro Tools 14 06-24-2022 07:21 AM
Video Playback Question - PT Ultimate 2022 on MacBook Pro M1 Pro/Max sheinke Post - Surround - Video 2 06-15-2022 05:35 AM
Pro Tools Ultimate / Pro Tools perpetual license renewal coming up soon... Justin1524 Pro Tools 1 06-21-2021 05:43 PM
Pro Tools Standard->Pro Tools Ultimate Cross-grade clarifications. Akiz Licensing & Accounts 8 08-30-2019 10:34 AM
Ultimate portable solution? macbook pro vs. air tonejunkee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 17 01-03-2011 12:22 AM
