Old 04-27-2016, 04:47 PM
Dan Smith's Avatar
Dan Smith Dan Smith is offline
Default S6 Bug Report: Shift Modifier Latching with Soft Keys
I'm using the default soft keys set. When I try to "save as" using the Shift modifier and the clear button, after the save completes the shift button is still engaged. It seems to latch. So any keystrokes or mouse commands function as if I'm holding down shift on my keyboard. Pressing shift on my keyboard does nothing to cancel out the latching. I must press the shift modifier on the S6.
It doesn't happen with all shift modifiers, and I haven't done much testing (or noticed issues with other modifier keys) However, I think it might have something to do with a dialog coming up on the computer screen. If I program another soft key using the shift layer and the eucon command "select all" it acts as it should, releasing the shift functionality. But if I create a soft key to create a memory location, which brings up a dialog box on screen, the latching shift bug is back.
Can anyone else confirm?
Windows 7. PT 12.5. S6 M40 v2.1.1.68
Old 04-29-2016, 07:39 AM
creativecontrol's Avatar
Default Re: S6 Bug Report: Shift Modifier Latching with Soft Keys
Greetings,
I verified that exact behavior here. Checking into it to now.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 05-29-2016, 01:33 PM
Marsdy Marsdy is offline
Reproduced here.
I think Eddie has already logged this as a bug?
http://duc.avid.com/showthread.php?t=378811
Dave Marsden
UK
Old 05-29-2016, 01:39 PM
Dan Smith's Avatar
Looks like it. Thanks Dave. I searched a little in the forum for similar threads. But I didn't find yours.
I have tested other modifiers and it seems to latch all of them. So I've stopped using the modifiers plus soft key combos.
Softkey shift modifier possible bug? Marsdy Avid S4/S6 4 03-15-2016 01:51 AM
S6 modifier keys not functional after 2.0.1 update sauna-l Avid S4/S6 2 10-09-2015 12:15 AM
D-Command Modifier keys not working Touchwood Studios ICON & C|24 3 03-01-2011 09:12 AM
C|24 Modifier Keys in 8.0.3 paulmellors ICON & C|24 1 02-10-2010 08:46 AM
Modifier keys...anyone remember Workman Pro Tools TDM Systems (Mac) 7 10-24-2005 03:08 AM
