Old 12-09-2024, 12:34 PM
TurboD TurboD is offline
Default Audio stutter when browsing the web on Sonoma
I recently updated my M1 Max Mac Studio to Sonoma while I had some downtime between projects. I now get massive stuttering in Pro Tools when I do something in a web browser in the background.
For example, if I click on a video in Chrome or Safari while Pro Tools is in play, the audio will begin to stutter horribly and will only stop when I close the browser down.
It never used to do this on Monterey which I came straight from. I'm on the latest version of Tools, latest versions of browsers, last version of Sonoma. It doesn't matter how intensive my Pro Tools session is - it'll do it even if I have a single stereo track playing with no plugins on.
Any thoughts? I've already tried lowering my disk cache in PT to no avail and I'm nowhere near maxing out my 32 GB integrated RAM.
Mac Studio M1 Max, 32GB RAM, Sonoma 14.7.1
Pro Tools Studio 2024.10.1
Neve 1073 SPX-D
Lynx Aurora 16
2x Avid S1
Old 01-05-2025, 09:57 AM
Default Re: Audio stutter when browsing the web on Sonoma
Bump...!
Neve 1073 SPX-D
Lynx Aurora 16
2x Avid S1
Old 01-05-2025, 01:18 PM
_JJ_ _JJ_ is offline
I'll give it a go. Maybe you didn't get many replies because of the question: You're asking why ProTools can't continue playing seamlessly while another app is trying to play audio? And that's something you used to be able to do in Monterey? Are the two apps competing for the same audio interface? That would seem like the most obvious cause.
It seems there have been some changes in the Mac OS recently with the appearance of the orange mic icon and how PT needs to be granted "Microphone" access regardless of the actual audio source. But if this particular functionality is important to you, try assigning the two sources to different output devices. PT to its own DA (isn't the S1 just a controller?) and the Mac OS to internal speakers. Just an idea.
2023 MacBook Pro 15,8 (M3 max)
Mac OS 15.2 (Sonoma)
PT 24.10.2.205 (Ultimate)
TB Native + Omni at home
Apogee Duet 3 on the road
Old 01-05-2025, 02:38 PM
Ed Douglas's Avatar
Ed Douglas Ed Douglas is offline
How are you routing your system audio?
In my case, I have my system audio output set to the 6 chan PTAB and have an aux within my protools session set to that as an input - I monitor everything in 5.1 through my PT sessions. I had some clocking issues develop resulting it all sorts of stuttering and glitching until someone suggested incorporating the PTAB into an aggregate device with drift correction enabled.
That solved it for me.
Including this on the outside chance it may prove helpful.
Neotech Concepts
http://www.imdb.com/name/nm0235036/
! sonic gymnastics for the illusionary arts !
2022 Mac Studio Max 64GB / 1TB, macOSX 14.7.2, 2019 i9 MacBook Pro (15,3), macOSX 15.3, PT Ulti 2024.10.1, DAR 5.3, MDA Creator1.5, Rx11 Advanced, Ozone 10 Advanced, Kontakt 8, Soundminer v6.1Pro, Spanner 4, PaulXStretch,
EuControl 2024.10, Avid Control 2024.10.1, Avid S1, iPad Pros 12.9" gen 3 & gen 4, Apollo 8 Duo, UAD-2 Satellite Quad, Glyph 2TB tb3 NVMe SSD, x2 Glyph 2TB SSDs, x1 Glyph 4TB SSD, OWC tb3 Dock, 8TB WD850x, OWC Thunderbay 8 62TB
Old 01-06-2025, 02:05 AM
prspn prspn is offline
Yes what kind of audio interface are you using?
RME for instance have done several recent driver updates to fix issues like this, both Apple Silicon and Sequoia/Sonoma related.
Old 01-06-2025, 05:23 AM
Thanks for the replies everyone. To answer the questions:
Yes, I used to be able to do this before updating to Sonoma. My setup uses a Lynx Aurora and a Neve 1073 SPX-D aggregated, with the Lynx clocked to the Neve. The Neve is my main mix DAC, feeding an analogue in on my Crane Song Avocet, while my system audio and rough mixes etc go via AES from the Lynx to the Crane Song.
Being able to run a Chrome browser in the background playing YouTube/Dropbox/whatever audio allows me to A/B between my mix and other references from the artist on separate buttons on my Avocet, so I'm often jumping between my mix playing in PT and a Chrome window playing audio/video.
It has never been a problem before upgrading to Sonoma, but now playing media or even opening a photograph on Chrome while PT is open causes massive stuttering in Pro Tools (not the system audio though!) which is only rectified by closing down the browser window.
I'm on the very latest Lynx drivers which are for Sonoma.
Neve 1073 SPX-D
Lynx Aurora 16
2x Avid S1
Old 01-06-2025, 05:51 AM
tope d's Avatar
tope d tope d is offline
I tried to reproduce this with and without an interface but was unable to.
Have you tried clearing your Pro Tools Cache? Is the same happening?
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
Old 01-06-2025, 06:05 AM
Hey Tope, thanks. I've just cleared the PT Cache but no change.
What's odd is that it records into the audio, so it's not just the main output of Pro Tools. If I do a realtime commit of a track through a hardware insert, for example, the stuttering gets printed into the new audio.
Neve 1073 SPX-D
Lynx Aurora 16
2x Avid S1
Old 01-06-2025, 08:43 AM
Dumb question but - is your system audio and PT operating at the same sample rate or is your external gear is trying to leap from one to another? System audio details can be set in Applications >> Utilities >> Audio MIDI Setup.
Old 01-06-2025, 09:12 AM
Not a dumb question at all! But yes, all the same sample rate.
Neve 1073 SPX-D
Lynx Aurora 16
2x Avid S1
Waking a display makes audio stutter acacia Pro Tools TDM Systems (Mac) 5 11-04-2010 09:01 PM
Digibase errors causing crash when browsing for audio meatmarketstudios 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 04-11-2008 08:45 PM
Audio stutter with other audio apps beside Protools gmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-17-2008 07:38 AM
importing audio cd to PT...stutter dubhausdisco1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-19-2006 07:43 AM
Stutter in Garageband using core Audio 6.7 JohnnyC44 General Discussion 0 02-24-2005 10:36 PM
