Old 12-09-2024, 08:21 AM
Drywsef Drywsef is offline
Default HDX Card Parts?
Hello all,
I have an HDX card with a broken Port A. I was once working on my computer, when it suddenly jerked downwards with a Mini Digilink cable still in Port A. Unfortunately, Port A suffered bent internal pins, so I have been getting along using Port B.
I finally reached out to Avid and was quoted a repair cost of ~$1200. I can't make any sense of that repair expense, as there are used cards on the market for as low as $1400.
I know this connector replacement is a simple matter of finding the part and attempting a very low-risk hot air rework. Does anyone have any wisdom for finding a Mini Digilink port? Someone found the old Digilink connector on mouser some years back... Any help is truly appreciated!
Mac Mini M4 Pro - HDX - Prism Titan - HD I/O
Old 12-09-2024, 12:51 PM
_JJ_ _JJ_ is offline
Default Re: HDX Card Parts?
How mangled did Port A get? That's a shame.
Based on a quick look at some online images of HDX cards, an old thread here on DUC, and a quick search of Mouser ... it might be this one:
https://www.mouser.com/ProductDetail...lImFemqw%3D%3D
I can't guarantee that's correct or that it would be an easy diy repair. Sounds like Avid's way of servicing it would be to replace the entire card.
2023 MacBook Pro 15,8 (M3 max)
Mac OS 15.2 (Sonoma)
PT 24.10.2.205 (Ultimate)
TB Native + Omni at home
Apogee Duet 3 on the road
Old 12-09-2024, 03:25 PM
Thanks, JJ. It seems that part is the connector for the old HD cards. I'm talking to a tech about dissecting a female mini digilink cable in order harvest the female connector, then install it on the card. This seems like the best route right now - unless someone happens to know the part ID?
Old 12-09-2024, 04:10 PM
A connector out of a cable is not likely what you want, you want a PCB mount connector. Look very closely there is likely a manufacturer or part number on the connector and you'll likely find it with a parametric search on Digikey or Mouser etc.
Old 12-09-2024, 05:01 PM
Photo of HD Native board looks like HDR IFYG1 on the metal of the connector. I can't find the 1FYG1 anywhere quickly.
But may be Honda Connector HDR series. Start there... https://product.htk-jp.com/EN-top1/s...ch/hdr_series# Don't confuse with other "HDR" connectors that are nothing to do with these.
Other threads on DUC in the past have pointed at Hirose MD*X series. Start there... https://www.hirose.com/en/product/c/...ns%3A26&text=#
Any technician should be able to measure the connector, maybe needing to de-solder it from the board and be able to identify exactly what part it is from what vendor and find that or a matching replacement.
Old 12-10-2024, 04:16 PM
Thanks so much for the help, everyone. The part appears to be the HDR-EA26LFYPG1-SLD+. I'll be ordering one and having a local tech install it. I hope this helps someone avoid Avid Repair in the future.
Old 12-10-2024, 06:41 PM
TOM@METRO's Avatar
Good to know. Thanks for posting. I hope I never need it, but one never knows.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 11
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 12-10-2024, 07:09 PM
Great! Can you please confirm when it's replaced that part number worked OK.
Old 12-30-2024, 01:00 PM
Just got the card back from the shop today with the new port installed - can confirm, everything works. This is the part. Only caveat is that the screw posts are hard to find so I simply recycled the ones from the broken port. All is well.
Old 12-30-2024, 02:44 PM
Honda FTW https://www.youtube.com/watch?v=80jfGb4N81Q
FS: Broken HDX card for spare parts or repair jacko Buy & Sell 10 10-08-2020 06:46 AM
HD Core Card Parts Missing eddierodriguez Pro Tools TDM Systems (Mac) 5 05-02-2015 01:16 AM
FS: Protools HD3 accel, Hackintosh parts, Lynx LT-HD card LDS Buy & Sell 0 10-06-2014 08:51 PM
i move some parts then parts are unmuted... montreal 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 17 05-08-2010 06:56 AM
Committing midi parts to audio. All parts ahead of bar line sad1robot Pro Tools TDM Systems (Mac) 2 04-25-2010 02:09 AM
