Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Carbon
Old 12-08-2024, 04:40 PM
Ptbright Ptbright is offline
Default Carbon vs Apollo latency with autotune
Hello all,
If recording a single channel, does the carbon offer reduced latency when tracking with autotune vs the Apollo? This would be my sole reason for getting the carbon as will likely use an external preamp. Has anyone who has used both for this application noticed a difference latency wise? Is it markedly reduced? Will usually record with autotune, a reverb, and compressor insert through console for monitoring purposes only.
Thanks
Old 12-08-2024, 07:35 PM
WHelbsing WHelbsing is offline
Default Re: Carbon vs Apollo latency with autotune
My Autotune Hybrid has 1,7 ms in DSP-mode (Carbon).
Old 12-09-2024, 05:01 AM
Thanks for replying. Is that at 48khz?
Old 12-09-2024, 12:09 PM
Yes.
Old 12-09-2024, 02:59 PM
digiot digiot is offline
As far as I can tell Autotune Hybrid (which is the only AAX DSP version available) was never updated for ARM. So you would need to tun it on either an Intel Mac or in Rosetta mode.
Old 12-10-2024, 02:16 AM
No.
Old 12-10-2024, 08:26 AM
martthie_08 martthie_08 is offline
Auto Tune Hybrid works fine in silicon native with Pro Tools.
Before I got the free upgrade to Pro 10 that was all I was using..
Old 12-15-2024, 06:23 AM
Kunst Kunst is offline
Hi - how does autotune hybrid work fine in silicon native if it hasn’t been updated for Apple silicon?
Antares tech support have told me repeatedly that it has not been updated for the new Apple chips, so in order to use it don’t you have to use ProTools in Rosetta mode?
Or is there something I’m missing? I can’t test it as I still have my Intel machine and haven’t upgraded to silicon yet…
Old 12-15-2024, 06:55 AM
it works fine here on Ventura M1 Macbook, no need for Rosetta.
no idea why Antares are not being clear on this!
Old 12-15-2024, 07:04 AM
Thank you for writing back.
I am completely baffled by this.
This is the response I got from Antares on the 4th December after asking them specifically about Hybrid:
Thank you for reaching out to us!
The following plug-ins are officially compatible with Apple Silicon:
Auto-Tune Pro 11
Auto-Tune Pro X
Auto-Key
Auto-Key 2
Auto-Tune Access 10
Auto-Tune EFX+ 10
Auto-Tune Artist
Vocal Effects (including Mic Mod and Harmony Engine)
Auto-Tune Vocodist
Auto-Tune Slice
Auto-Tune SoundSoap
Auto-Tune Vocal Compressor
Auto-Tune Vocal EQ
All current Antares Auto-Tune editions, as well as all Vocal Effects, are Apple Silicon Native – compatible on both Apple M1 and M2 machines.
Please note Auto-Tune Pro 9 is not officially compatible with Apple Silicon.
In the meantime, we recommend opening your DAW with Rosetta by following the steps below:
Locate your DAW in the Applications folder
Right-Click your DAW and select "Get Info"
In the Info Window, check the "Open in Rosetta" box
Please let us know if you need further assistance.
Best Regards,
Antares Support
Carbon vs Apollo noah330 Pro Tools 35 10-04-2023 02:36 PM
Carbon Ultimate/Autotune Promo SoundEng1 Pro Tools | Carbon 84 09-02-2021 09:00 AM
Any Carbon users who were using UAD Apollo before? Oblivion777 Pro Tools | Carbon 72 04-03-2021 04:51 PM
Strange Apollo Latency orangepopsongs01 Pro Tools 2018 11 06-07-2018 02:14 PM
latency with new setup ua apollo drewblue macOS 12 06-10-2013 06:20 PM
