  #71
Old 12-08-2024, 04:18 PM
AlexLakis AlexLakis is offline
Default Re: Sequoia... anyone?
I don't use Sonnox or McDSP, but Soundtoys plugins are working fine under Sequoia in Native mode. Latest version of Sequoia, Pro Tools, Soundtoys, and a buncha other plugins. The only time I see an error code is if I leave Pro Tools running over night. Otherwise it's smooth sailing here.
  #72
Old 12-08-2024, 05:03 PM
MixerGuy MixerGuy is offline
Originally Posted by Eric Lambert View Post
As reported above by a couple people, Soundtoys plugins are functioning normally in Sequoia.
I have but don't use Sonnox and McDSP plugs so can't report on them, however I've not seen reports of people having issues with either. Sometimes companies are just cautious about approving their products.
right..... but.....
McDSP literally said "There are currently some known issues with our Plug-Ins on MacOS Sequoia. We kindly ask that you do not update your system until we reach out via this ticket or subscribe to our newsletter."
MDW said " EQ6 has an ongoing graphic issue that we have been working tirelessly to resolve -a new release will be coming out very soon......"
and Sonnox posts on their website basically "Apple M4 chip = bad. "
so just sharing this info.
  #73
Old 12-08-2024, 05:18 PM
joeshepard joeshepard is offline
Out of curiosity, why are you using K5? One of the cool things about K8 is that you can remove older versions of Kontakt, leaving only the latest version in your plugin folder, and if you open an old session which used a previous version of Kontakt it will open into K8 just fine. I (and others) have tested this with sessions which used K7, K6 and K5 and all of the data and routing was properly imported into K8.
This is great to know!
I'm running K8. Nice to know I can nuke the older versions!
Thanks
MacBook 16" Pro Max 2TB 64GB
Ventura 13.6
Pro Tools Ultimate 2023.12 (Native)
Logic Pro 10.7.9
Eucon 2023.12
2 Artist Mixes
Avid Control on an iPad
Soundflow & Streamdeck XL
UA Apollo|x|16, UA Apollo Twin|x, UA TB Octo Satellite
  #74
Old 12-08-2024, 09:22 PM
smurfyou smurfyou is offline
Originally Posted by MixerGuy View Post
right..... but.....
I looked at Sonnox out of curiosity and you're right. They specifically point out M4 is the problem not Sequoia. They say "serious issues".
~Will
  #75
Old 12-09-2024, 04:00 AM
saqibhassan saqibhassan is offline
Yes, im on MBP 16" M4MAX. Sonnox dynamic EQ crashes Pro Tools, vst3 works. All other Sonnox is fine.
  #76
Old 12-09-2024, 12:46 PM
Ru_C Ru_C is offline
Thanks for confirming that works. yes it sounds weird that I wanted to keep K5 going, but I wanted forward/backward compatibility with an Intel Rig stuck on Catalina...that computer unfortunately just decided to give up the ghost, so I've accepted my fate & swapped it over for an Mac Studio+Sonnet Echo Express III Chassis arrangement & upgraded to K8..all seems to be running smoothly, I just need to do that 'quiet fan' replacement procedure on the noisey fan in the chassis..
A Rig: (Studio) M1 Max Studio - 64gb ram - OSX 15.1.1, PT Ultimate2024.10.1, HDX in Sonnet III, AVID I/O16 Analog i/o x2, 40 fader D-Command ES
B Rig: (Home/Office) M1 Mini - 16gb, OSX 15.1.1, PT Ultimate2024.10.1, HD Native Thunderbolt, Omni, Avid Artist Control
http://www.lostboysstudio.com
  #77
Old 12-21-2024, 01:45 PM
Philthy Philthy is offline
They specifically single out ILok as being the company that needs to address it.
Phil Mann
Silk City Music Factory - CT Recording Studio
  #78
Old 12-21-2024, 02:44 PM
Daveporter33765 Daveporter33765 is offline
Thankfully, some companies, like Universal Audio, are working directly with iLoc to resolve issues Luna is having with Apple M4 processors, Sequoia and iLoc. What they learn may solve all the issues with M4 processors, Sequoia and iLoc…at least I am hoping so.
Luna 1.8, Logic Pro 11.1.1, Cubase Pro 14.0.10, Studio One Pro 7.0.2, Pro Tools Studio 2024.10.1, UAD Software 11.5.2, UA Connect 1.4.20, UA Apollo 8, UA Apollo Twin Mk 2 (2), UAD-2 Thunderbolt Satellite Quad (2), Fractal Axe Fx III Mk. II Turbo FW 27.03, USB FW 1.17 and Axe-Edit III 1.14.07, Studio A: Apple Mac Mini, M4 Pro 14 Core CPU, 64 GB RAM, 1 TB SSD, 20 Core GPU, 1 Gb/s Ethernet, MacOS Sequoia 15.2. Studio B: Apple MacBook Air, M1 10 Core CPU, 16 GB RAM, 1 TB SSD, X Core GPU, 1 Gb/s Ethernet, MacOS Sequoia 15.2.
  #79
Old 12-21-2024, 06:18 PM
That was not there when I checked.
~Will
  #80
Old 12-21-2024, 09:40 PM
Eric Lambert's Avatar
I wonder if their data is changing. That's not a great sign but at least they're working on it.
Sequoia !? digiot Pro Tools | Carbon 32 12-26-2024 09:31 AM
One Sequoia Weirdness sw rec macOS 2 11-05-2024 09:09 PM
MacOS Sequoia? Paul Alvarez macOS 23 10-14-2024 12:49 PM
MC Transport and Sequoia TechSpec Artist Series 3 01-17-2012 01:44 PM
Sequoia vs. Samplitude... Ralph K 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 10-22-2004 10:58 AM
