#21
Re: PT 2024.3 NEW issue MIDI LATENCY
I do not. I do have melodyne running but not autotune
#22
That's a good question, because Autotune produces about 3400ms of latency, so I removed that and stacked up a bunch of UAD plugs to simulate the same amount of latency and same problem. Again, downgrading resolves the issues.
5K Retina 27" (2020) iMac OS 15.1.1 Sequoia 3.3 GHz 6-Core intel Core i5 AMD Radeon Pro 5300 4 GB 64 GB 2667 MHz DDR 4 Internal 2TiB SSD Pro Tools 2024.10.1 EuCon 4.8.6.41 / 2024.10.0.19 UA Luna UAD 11 UA Apollo Twin X Avid S1 / Fire10 - 21.8.1.0 PreSonus DigiMax FS 8-input ADAT Dynaudio Monitors PreSonus Temblor 10 Sub Check my Music out here: Paul G YouTube Paul G Bandcamp |
#23
Out of curiosity, have you tried opening up Instrument View and seeing if the problem happens if you set the MIDI output directly to the VI plugin instead of "Chain In"?
Also, are the notes only printing late, or do you also hear them late as you're recording? In previous versions of Pro Tools, notes sound late while recording (by heavy plugin latency like Autotune on another track), but they print exactly when you hit them (not where you heard them when playing), which is also problematic. |
#24
NO Auto Tune was involved. Just Midi and VI
Shefi Mac Studio M2 Ultra 128GB, OS 13.5 |
#25
There was No way to cancel Chain Mode.
#26
Not sure if this is related. I'm still in 2023.12.1, having recently upgraded from a PT 2021.6, 5,1 cheesegrater HDX rig to an M1 Studio Ultra 64GB RAM. I am finding the MIDI WAY zippier on the new rig. But I am also finding I still have to jump through the same annoying hoops on this new rig when I am recording MIDI in sessions with a bunch of plugins, ie. I have to disable any high CPU plugins, and disable plugins on MIDI Aux tracks that introduce enough latency to be annoying. And/or I will turn off Delay Compensation. Should I be having to do this on an M1 Studio Ultra with a Buffer of 64? I am currently working on a mix with the Weiss De-Esser on a few tracks, which is a CPU hog. I have about 6000 samples total system latency, and I can't record MIDI without annoying lag. I have to disable the Weiss De-Essers, and disable any Non-VI plugs on VI Aux tracks. Should I be having to do this? (I use Aux tracks for all VI's. That should be fine, right?)
My expectations for Pro Tools MIDI are soooo low that I almost don't think about it anymore. But could it, should it possibly work better in terms of ADC, MIDI latency, etc.?? My main issue has to do with recording MIDI, the latency between pressing the keyboard and the sound. So frustrating...
-------------------------------------------- Mac Studio M1 Ultra 64GB RAM, Pro Tools Ultimate 2023.12.1, Ventura, Apollo x4 / Avid HD IO 16x16 w/ HDX, UAD Octo |
#27
If you trash the prefs does it go away. and if you then open another session or start a new one does it come back? Marianna
Marianna Montague Sr. Dir. CX and Community | Customer Advocate [email protected] cell +1 (813) 493-6800 AOL IM avidmarianna Twitter Avidmarianna We're Avid. Learn more at www.avid.com |
#28
So thinking that was the main issue, I did a full uninstall of 2023.9, upgraded to 2024.3.1 and then made sure all the midi outs were set properly and the issue returned. Going back to 2023.12, setting them either way had no effect, and things worked as it was supposed to. Quote:
I have a feeling this is highly related to another open case I have: 04787750. I'm not a software engineer, however a solution engineer (SE) by trade and I believe ADC on midi is (technical engineering term) dorked up.
#29
I think I'm mostly following y'all.
But yeah just to reiterate, I think it's useful to consider two different events when testing this stuff:
I'm suspicious that I actually think this new behavior might be correct, not a bug. If you hear a note late because of plug-in latency and it prints at that delayed moment you heard, that seems correct. (Gotta turn off the big latency plug-ins, admittedly super annoying). If you hear a note late because of plug-in latency but it actually prints at the exact moment you hit it (earlier than what you heard while playing), that seems wrong to me. That's the previous behavior. Most ideally, you'd hope they could make it so that whatever VI you're currently playing/recording both sounds and prints without any delay at all, no matter what delay-inducing plugins are active. |
#30
I have done a lot of testing on this since seeing this thread. This is definitely a major bug for sure. Check out my screen recording (forgive me breathing and clearing my throat lol)
MIDI Latency It is clear that using Chain In vs. using channel 1 of the plugin on the track does not provide a different result as far as the MIDI printing differently than how it does on playback. In my testing with two Pro-L 2s it is always early! Seems like it must be a pretty gnarly bug that needs to be prioritized. I can only hope that it will be of top importance to fix this for 2024.6! Deciding if I should revert... Same thing with Auto-Tune as Pro-L 2. Nothing related to specific plugins. Entirely related to delay compensation generally being messed up for recording MIDI data on this version of PT.
Pro Tools Ultimate 2024.10.1 macOS Sequoia 15.2 MacBook Pro 16" Apple M2 Pro with 12‑core CPU, 19‑core GPU, 16‑core Neural Engine 32 GB unified memory 1TB SSD storage |
MIDI Thru Latency Issue | The Style Guide | Pro Tools 11 | 4 | 12-08-2016 09:53 PM |
Latency issue with midi function of Mbox3 | deepakkabirgyan | General Discussion | 1 | 12-22-2013 11:29 AM |
Midi Latency Issue - Please help me someone | metro williams | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-23-2010 09:18 AM |
MIDI beat clock latency issue!! | overseasmusician | Pro Tools M-Powered (Win) | 0 | 11-04-2007 05:57 PM |
