Old 05-30-2024, 12:47 AM
songman songman is offline
Default master level
MacPro MacOS 10.8.5 and HD3 TDM v 10.3.7
Should I keep the master fader at 0dB? See
https://www.youtube.com/watch?v=9mcw4U-9O5o
Old 05-30-2024, 04:34 PM
Default Re: master level
Put it wherever you need it. The most important thing is to not hit the red on the Master Track meter. My personal observation: if I need to pull it down more than 3-4db, I will either lower everything in the mix(except AUX tracks fed by Post-Fade sends), insert a Trim plugin to knock down the level on the master, or(preferred) insert the Trim plugin(default to -8db) on every Audio and Instrument track.
Old 05-30-2024, 06:45 PM
JFreak's Avatar
JFreak JFreak is online now
Use pre-fader metering to see if levels are too hot. Then use trim if some track is too hot.
Janne
Old 06-01-2024, 04:39 AM
Many thanks for your helpful comments and suggestions!
Mono channel meter level lower than Master’s meter level Armando Pro Tools TDM Systems (Mac) 3 07-07-2019 05:51 PM
Master level question... Varela General Discussion 6 11-13-2012 06:53 PM
Level boosting my 5.1 master mix? abes Post - Surround - Video 10 09-27-2011 08:43 AM
Master Level Meter Numbers agrey80 Tips & Tricks 1 09-08-2010 06:31 PM
Master Fader Level TERRANCE Pro Tools M-Powered (Win) 2 06-01-2005 02:08 PM
