Old 07-20-2012, 06:52 AM
Chingy Chingy is offline
Default New Mbox 3 Pro Driver Issue
I upgraded to the new Mbox 3 Pro drivers since they fixed the speaker select button, but I've noticed a new problem now. More times than not, when I boot my Mac and then turn on the Mbox, no sound comes out. I have to cycle the power and then it works. Anybody else have this issue?
Thanks!
Old 07-20-2012, 08:04 AM
serio serio is offline
Default Re: New Mbox 3 Pro Driver Issue
Does this happen if you turn the Mbox on before the Mac? This is my usual procedure and I have not had that problem.
21.5" Mid-2011 iMac i5 QUAD 2.5GHZ 4G RAM ML 10.8.5--Pro Tools 10.3.9--Avid Mbox Pro / 003R--ICY DOCK MB664UEA-1S FW400 With: 500GB Samsung HD502HJ
Old 07-20-2012, 08:31 PM
I will try that. I thought for Firewire with Mac you were supposed to turn it on after since it wasn't as robust as USB and could fry your device? Maybe I was mistaken.
Old 07-21-2012, 06:02 AM
jryser's Avatar
jryser jryser is offline
Default
Start wit ur hard drives, then Mbox, then ur Mac! Interestingly there is a bug in the new drivers for some of us. I lost my tuner - which is no big deal - but I did get with Avid and we discovered it. The fella I worked with was extremely helpful and I will get with both of you as soon as I learn something if u have that issue! I'm really glad my speaker buttons actually work now!
MacBook Pro Retina M4Max, 128GB RAM, OSX Sequoia 15.5, PT Carbon, PT Ultimate version 2024.10.2, Glyph External Drives. Outboard gear - RND Shelford Channel, API TCS II, SSL Bus +.
Issue with Mbox 2 pro... Will I need to download a driver to use it? DeenaJackman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-11-2011 06:36 AM
MBOX 2 Driver Issue DJ Pete Marriott 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 08-21-2010 06:56 PM
mbox 2 driver installation issue asurademon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-25-2009 06:12 PM
MBox Driver Issue JosephJones 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 02-16-2009 10:36 PM
Mbox 2 driver issue with sound forge 8b SethC General Discussion 0 11-23-2005 10:52 AM
