Old 04-15-2008, 05:40 PM
aperez's Avatar
aperez aperez is offline
Default Pitch/Time Shift glitches in PT 7.4
Hi, first post here. I've searched the forum but haven't found any related post.
Since I installed v7.4 I get glitches in the audio when I use the Audiosuite pitch shift/time stretch tools. The effect is more noticeable when I pitch down than when I pitch up and becomes worse with higher values of pitch shift.
Being one of the tools I use recurrently, it is starting to become a real obstacle.
Has anyone had this problem or knows what might cause it?
Thanks!
Old 04-16-2008, 03:05 AM
aperez's Avatar
Default Re: Pitch/Time Shift glitches in PT 7.4
forgot to mention...
I'm running PT 7.4cs3 in OSX 10.4.11 on a MacBook Pro with a 2,33GHz processor
Memory is 2GB 667MHz DDR2 SDRAM
and interface is Mbox2 Mini
cheers
Old 04-16-2008, 04:26 AM
Phil Ogden Phil Ogden is offline
Can you explain what you mean by 'glitch'? It's just that there are limitations as to what this plug-in can do without the processing introducing audible artifacts particularly where polyphonic audio is concerned (e.g guitar). It might be that the plug-in simply cannot do what you're asking of it transparently.
http://www.myspace.com/philogg
Old 04-16-2008, 10:45 AM
aperez's Avatar
thanks for replying Phil. You are right my description isn't clear. By glitch I mean audible clicks that weren't there before. I don't mean the pitch bend artifacts that make things sound metallic but very short digital clicks that appear randomly.
As I said, I use this tool extensively and I never noticed this effect when running 7.3 ... I am even thinking on downgrading now...
Old 04-23-2008, 10:04 AM
aperez's Avatar
(thought i posted this already but it hasn't come through)
It seems to be difficult to get a post read due to the huge amount of issues that people bring up. In a last attempt to put this forward...
The problem persists and I am now thinking of downgrading to from 7.4 back to version 7.3. Are there any known issues with this kind of operation? Is it possible to open sessions created in 7.4 with 7.3?
Any comment will be much appreciated
Thanks in advance!
BIG BUG: Wrong playlist calculations when using AS Pitch 'n Time or Avid Time Shift Franco1967 Pro Tools 11 1 01-25-2014 12:31 PM
PT8 - Pitch 'n Time LE and Time Shift - very slow to operate Richard901 General Discussion 3 12-30-2008 10:00 PM
Time Shift: Why no pitch/time strap?! EricWillhelm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 09-17-2006 06:44 PM
Time stretch and Pitch Shift ModaRecords Pro Tools TDM Systems (Mac) 10 12-31-2004 03:53 PM
Pitch Shift Time Compression stut5 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 07-03-2003 10:24 PM
