Old 07-26-2005, 09:28 PM
djkiller djkiller is offline
Default normal decibel level/master mix
does anyone know the proper decibel level the master fader should be set to during a bounce? i have some audio i run live and i need a better decibel level and eq/master.
Old 07-26-2005, 10:12 PM
PsyCoNo PsyCoNo is offline
Default Re: normal decibel level/master mix
I think clarification is needed... is this the CD being sent to be mastered or are you talking about mastering itself? Also, I don't know why the master fader should be changed much beyond zero if the mix is good.
Old 07-26-2005, 11:26 PM
i think i figured it out. i thought the master channel needed to be at 0db. i did that and added a dither and L2 i'm re bouncing all my tracks right now and they sound awesome. no it's not for a cd it's for live audio.
Old 07-28-2005, 09:38 AM
rockrev rockrev is offline
Did you add the dither after the L2? Did you know that the L2 comes with an internal dither process already (that can be disabled)? All the L2 does is squash your waveform - IOW it's not enhancing anything, it's simply making it louder. Louder does not mean better, so take it easy on the brick maker (you'll thank me later). For best results, set your master fader to unity gain (0db), make sure it and no other tracks "red out," then send it to a real mastering engineer (you'll thank me for that later too).
rockrev
End world poverty: ONE
Old 07-29-2005, 09:21 AM
Chris Cavell Chris Cavell is offline
it's for live audio
Then why are you limiting at all? Just turn up the gain at the mixer...
Cavell Studios
Old 08-06-2005, 03:12 PM
sometimes my band doesn't have a sound guy and it's up to me on top of having my hands full playing guitar to catch things live. so i need all the tracks set to the exact same volume as close as possible. it's not the point of limiting the tracks it's getting them set exact. so far thoug i played a kick ass show last night with the mix i said i used and it's working just fine
Master level question... Varela General Discussion 6 11-13-2012 06:53 PM
low input level on 11R - is this normal? Ralf_T Eleven Rack 1 08-30-2012 05:26 PM
Normal input level behaviour ? stevegalante Pro Tools TDM Systems (Mac) 3 07-14-2008 07:27 AM
Decibel level wackyza 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-19-2005 03:02 PM
Normal noise level for Dual G5? RMcFarland 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-02-2004 11:01 AM
