Old 05-18-2023, 04:37 AM
mfranken's Avatar
mfranken mfranken is offline
Sounds In Sync
Default EdiPrompt v3 has been released
Here's a list of what's new in this major release:
  • New integration for Stream Deck to control Cue List and Transport functions
  • Set Audio Outputs for Cue Beeps and Take Speech
  • Added window to convert Netflix TTAL files to MIDI for ADR recordings
  • Multiple updates for macOS Ventura
  • Compatible with ARM (Apple Silicon) macs by providing a universal binary app
  • Display Cue List line text while Pro Tools isn't running
  • Bug fix to support HUI MIDI controllers when using hardware ports
See this blog post for more details.
To download the app installer, go to http://www.soundsinsync.com/download/
Mark Franken, MPSE
Dialogue editor/supervisor IMDb
Creator of 'EDI' applications for sound post editors
Old 08-29-2023, 04:52 AM
mfranken's Avatar
Sounds In Sync
Default Re: EdiPrompt v3 has been released
Just released #EdiPrompt v3.0.1 with the following updates:
  • Fix while loading preferences file on start up to stop potential hang in non-English countries
  • Updated PACE license software
Mark Franken, MPSE
Old 09-21-2023, 07:47 PM
mfranken's Avatar
Sounds In Sync
Just released #EdiPrompt v3.0.2 with the following updates:
  • Changes required for compatibility with Pro Tools 2023.9+ on macOS
  • Minor update to select first row in Cue List when a file is loaded
Mark Franken, MPSE
Old 05-02-2024, 11:20 PM
mfranken's Avatar
Sounds In Sync
Just released #EdiPrompt v3.1.0 with the following updates:
  • New checkbox 'Display text when Locate or Rename and Locate are clicked' on 'Text' tab which displays the text of the selected cue before Pro Tools plays or records
  • New checkbox 'Allow when A/V Bypass is active' on 'Status' tab allows the record status overlay to be shown when A/V Bypass is active (blocking A/V cues)
  • New 'Cue List' menu items added for existing functions: 'Display Cue Text', 'Toggle Record State', and 'Create New Cue'
  • New 'EdiPrompt Commander' StreamDeck plugin (v1.1) containing four new buttons 'Show Cue Text', 'Toggle Cue Record State', 'Create New Cue', and 'Focus Pro Tools'
  • New preference to hide audio devices from the Audio I/O tab that have a channel count larger than specified. Previously this was set to 6
  • The ability to create and import MIDI files containing markers at the same location when the cue numbers were not generated by EdiCue and don't contain alpha suffixes
Mark Franken, MPSE
Old 09-10-2024, 07:17 PM
mfranken's Avatar
Sounds In Sync
Just released #EdiPrompt v3.1.1 with the following updates:
  • Fix for save and recall of 'Record Status' setting on main tab. Bug was created in v3.1.0
  • Fix for intermittent crash during app startup when a missing audio port or MIDI port message is displayed
  • New Pro Tools control code for compatibility with macOS Sonoma when caps lock is pressed
  • Minor update to the way the 'Cue List' menu 'Toggle Record State' works
Mark Franken, MPSE
[IMG] code is Off
WTB EdiPrompt Meads Buy & Sell 0 01-21-2016 01:36 PM
Autocues in Ediprompt not making 'T' Midi file for streamers? Soundburst Getting Started 0 01-15-2015 03:17 AM
When Will PT 11 Be Released? hitshack Pro Tools 10 3 10-27-2011 10:23 AM
Anyone using Ediprompt ? simon mog Post - Surround - Video 2 11-23-2010 09:18 PM
EdiPrompt - New app for cueing Actors/Foley artists mfranken Post - Surround - Video 4 05-12-2009 05:54 PM
