Negative Video Sync Offset???
Can any of you describe a situation where I would need to modify my QT offset to a negative quarter-frame number? A number as seemingly incomprehensible as -65? This was a downloaded H.264 QT that I converted (as I do all my QTs) to DV. I was under the assumption that it would/could only ever be a positive offset to make up for the inherent delay in the QT output process. I checked and rechecked, but the picture started WAY early compared to where it was on the timeline.
I rebooted everything, twice, with no improvement. Because this was accompanied by other flaky video related behavior, I ended up having the video ingested in another room, and loaded it up by playing it into the Mojo. That seemed to do the trick. I just couldn't wrap my head around that offset. -Steve 7.4cs3 OSX 10.4.11 Dual 3GHZ Intel |
Re: Negative Video Sync Offset???
I believe I had this problem 2 weeks ago. Try upgrading to cs4 (that worked for me). It could be a bug in cs3 that Digi doesn't specifically address. Compare the sync between out the firewire and watching in the QT window.
Best of luck |
I also had a similar issue recently. I had to use a -100 offset. but it was fine when converted to MFX file. I noticed the session started at 00:10:00:00 and the quicktime was at 01:00:00:00. when i moved the quicktime to the session start there was no problem. then we saw the CS4 update which said this:
Mac Only: Fixed: A QuickTime Movie Played Using Mojo or Mojo SDI Could Jump Out of Sync (Item #100497)- This would only occur if playback crossed 35min-45 seconds from the session start So basically any quicktime movie past 35min-45sec from the session start would be out of sync. |
Thanks guys... will consider the upgrade to cs4.
I've also been able to repeat this behavior. It only happens when I have Avid video and QT video in the same session. They're on different tracks obviously, but whenever I have mixed video media in this way, the QT becomes unstable. Importing the session, without the avid track solves the problem.' -Steve |
Video Sync Offset jumps | simonchase | Post - Surround - Video | 21 | 02-21-2014 08:32 PM |
Mojo Video Sync Offset | TAFF | Post - Surround - Video | 4 | 04-01-2011 11:42 AM |
Video sync offset | samplaire | Post - Surround - Video | 9 | 11-16-2010 05:50 AM |
Keeping Laybacks in Sync (delay compensation and Video sync offset) | edit machine | Pro Tools TDM Systems (Mac) | 6 | 11-15-2010 11:33 AM |
Video sync offset changes | Studio Studio | Pro Tools TDM Systems (Mac) | 0 | 09-15-2008 06:33 AM |
