Old 09-09-2019, 06:50 AM
Default Re: "Pro Tools could not set sample rate to specified value.."
Launch PT with 'N' pressed and see if you have correct interface selected
Old 09-09-2019, 07:09 AM
GuyPicks GuyPicks is offline
thanks, no it didn't work.
I had to trash prefs, shut down mac, turn off audio interface, turn on interface, turn on mac and that worked for me... good grief...
Hope this doesn't happen again.
It's like PT got stuck on something.
Thanks for the come back. :)
My System
Mac mini M1
OS X 11.6.4
PreSonus 1824c
Faderport 16
Pro Tools Ultimate 2021.12
Studio One 6.5 Pro
Logic Pro X
Old 09-14-2019, 07:33 PM
Songster Songster is offline
Make sure your Audio Devices for your Windows is disabled and restart. For some reason you can't use any interface for Windows programs at the same time as Pro Tools ... I hope that helps ... it was driving me crazy ... sweetwater tech support solved that for me
Old 08-07-2024, 02:19 PM
rdbrd rdbrd is offline
I ran into this same problem.
The solution for me (given that I was using a Focusrite 18i20 audio interface) was to go into Focusrite Control -> Settings and manually change the sample rate to match the project I was working with - which I just happened to know was 96kHz.
Hope this helps. Good luck fellow travelers!
"The current playback engine does not support a sample rate of 48 KHz" error when tr eyeshow Pro Tools M-Powered (Win) 19 09-09-2015 10:10 AM
"current playback engine doesn't support sample rate" terracestudio Windows 2 04-17-2015 02:37 PM
FIX... Pro Tools could not set sample rate to specified value "Windows" and MOTU 828x Rockan0n Pro Tools 11 0 09-17-2014 07:38 PM
"Pro Tools could not set sample rate to specified value" error with MadiXtreme redbull Windows 2 08-26-2012 09:45 AM
"...Pro Tools cannot set sample rate to specified value"? aleheroix macOS 2 12-10-2011 01:47 PM
