Old 01-08-2025, 11:53 AM
marco_fantino marco_fantino is offline
Default 5.1 channel order
Hello, I’ve just made a clean installation on windows 11 (24H2), Protools Ultimate 2024.6 on HD Omni and now on 5.1 track if I solo the Ls, I can listen the LFE, if I solo the Rs, I can listen the Ls, if I solo the LFE, I can listen Rs. No hardware is changed. I checked the output order and seems ok. If I swap in the old disk, Protools works perfectly with the right order. I understand seems that is SMPTE instead Film buy I checked everywhere and everything is set on film order, even on HD omni monitor output Even the old project swap the channel. The funny thing is, if I switch the old disk, everything works perfectly in the right order. Seems stupid buy never happened. Could somebody help me? Thanks
Old 01-10-2025, 06:21 AM
ctv mtl ctv mtl is offline
Default Re: 5.1 channel order
Hello Marco,
Maybe try to export your i/o setup from your old disk and then import it back in your new setup.
Best of luck!
Please report back if that worked for you...
Franky
HTML code is On
5.1 channel order wrong. LDS Post - Surround - Video 1 10-30-2019 07:45 AM
5.1 file channel order lastbeethoven Post - Surround - Video 49 06-22-2019 03:44 PM
5.1 file channel order marcelkavka Post - Surround - Video 21 12-19-2018 09:35 AM
Locked Channel order in Bus bcslaam Pro Tools 11 3 08-29-2013 12:11 PM
