Old 02-16-2006, 08:05 AM
buckaroo buckaroo is offline
Default Mbox inserts with outboard Compressor?
Can anyone tell me how to set up the inserts on my Mbox?
I have an external Behringer Composer compressor and would like to connect up the Mbox. Does the compressor then "compress" anything i hear coming out of the mbox or does it only compress recorded files going in?
Also im not exactly sure of the connections from the Mbox to the compressor? - i have 2 x insert cables (Y leads) can anyone help a newbie?
Also whats the best and simplest way to connect a Mac & Pc together so i can "fly" files across from Mac>PC then PC>Mac? I currently have a network with just a crossover cable so my Mac can share a Net connection, do i need anything else to transfer files back and forth?? and is it easy to set up?
Connecting outboard compressor to MBox RoxyRiot FireWire & USB Audio Interfaces (Mac) 0 05-01-2013 10:07 AM
Mbox with outboard Compressor buckaroo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-22-2006 02:51 AM
Connecting Outboard Compressor to Mbox buckaroo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-19-2006 08:47 AM
Mbox inserts with Outboard Compressor? buckaroo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-16-2006 10:51 AM
002, AI3, and outboard inserts... Amo Audio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-11-2005 02:58 AM
