Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2020
Old 09-17-2021, 10:06 AM
danonbass danonbass is offline
Default Plug In Presets Not Showing
I'm not able to access any plug in presets from the Preset Tab. I get nothing when I click on it or the arrow on the right of the tab. If I load a plug in that has a folder icon or load button I can access presets through there, but not the Preset Tab.
Mac Pro 2013
OS 10.15.6
PT 2020.9.1
Old 09-17-2021, 12:36 PM
Default Re: Plug In Presets Not Showing
Hmmm, did you do anything other than default settings when you installed the plugins(or are you talking about stock plugins)? Next, is it possible you are clicking the wrong thing? See screen shot for what to click to open presets on stock plugins. Not all plugins use this same method, such as Waves(which has the LOAD method). If you look at the screen shot showing the Waves plugin, you can see the list of presets accessed by the LOAD "button", but you can also see my personal preset under the same spot as stock plugins because I chose to save it there, instead of in the Waves spot accessed by that SAVE option(next to the LOAD option)
Old 09-17-2021, 01:56 PM
The stock plus tab is the one that's not working. The one from your photo of the 7 band EQ. The Load function works fine as well as does the folder icon which I think is UAD.
Old 09-17-2021, 01:57 PM
should read: stock plugs tab
Old 09-17-2021, 02:00 PM
I'm not sure if I've done something besides the default setting. I'm not sure how to check that. Let me see if I can find that out.
Old 09-18-2021, 10:31 AM
I don't see anything to indicate a settings issue, but I'm really unsure what to look for. Anyone have an idea of why this is happening?
Old 09-18-2021, 11:04 AM
Ben Jenssen's Avatar
The default plugin presets are stored in user/Documents/Pro_Tools/Plug-in_settings, have you checked if it's there?
Life-long audio enthusiast and small studio owner. Retired.
Mac Mini 2018, six-core 3.2gHz i7, 32 gb RAM.
Focusrite Scarlett 6i6 2nd gen, Dynaudio BM6's, Command|8, SSL UC1.
Pro Tools 2020.11.0.157, Mac OS 10.15.7.
Last edited by Ben Jenssen; 09-18-2021 at 11:07 AM. Reason: corrected: user/Documents/Pro_Tools/Plug-in_settings
Track Presets not showing in Workspace [solved] thanos4 Pro Tools 2018 26 10-17-2018 01:49 PM
Track Presets not showing up. [SOLVED] Vultage Windows 16 04-03-2018 12:42 PM
Presets Not Showing Up americanslidol Pro Tools 11 5 10-07-2015 04:24 PM
at times plugin presets not showing digidesigner VENUE Live Sound Systems 2 11-29-2009 12:33 PM
Plugins presets not showing francois Pro Tools TDM Systems (Mac) 1 09-15-2005 09:06 AM
