Old 01-20-2012, 04:13 AM
paulreed paulreed is offline
Default peak finder??
I just watched this video http://www.youtube.com/watch?v=Ci_y7...layer_embedded
and in logic it seems the software will find the peak in your track.
does Pro Tools have anything like this that I have missed for the last 10 years???
Old 01-20-2012, 04:43 AM
Emcha_audio's Avatar
Default Re: peak finder??
You can simply look at your wave to see which peak is the highest, then go to that point and play it while watching the meter, it will tell you the the actual peak level of the wave track.
When you get used to it, it's going to be faster than going through the menus (in logic) to get that find highest peak option.
Manny.
Wave-T.com
Old 01-20-2012, 05:03 AM
this is how I have been doing it, but it does not seem to always give me the peak, relying on my eyes. I often think I have found the peak, then play the track through and it was not.
I will put this into the ideascale.
Old 01-20-2012, 07:15 AM
daeron80 daeron80 is offline
Good idea. I love how Peak automatically scans for the peak and gives a readout of it in the lower left. It would be cool if PT would let you, like, select a region and do a Get Info-type command to see its "vitals." Or it could just show up in the tool bar along with the start/end/length.
David J. Finnamore
Nyquist was right.
PT 2021.6 Ultimate | Omni | macOS Catalina in a Trashcan 32GB
PT 2021.6 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 01-20-2012, 07:20 AM
PD-John PD-John is offline
Not sure if this helps, but I often find the Peak and RMS of a track by selecting the clip, then opening AudioSuite > Other > Gain and click "Find Level".
Old 01-20-2012, 09:21 AM
sounds like the way to do it for mastering purposes with the whole track bounced to left and right cause you could do it within your mastering session by selecting the whole song
It would be real nice to be able to tell the peak of a whole song without playing it through during mixing
Thanks
Old 01-20-2012, 06:54 PM
Thanks
Command-clicking on the little info box on the session Master fader will show the highest peak value of the song, but it's probably not the most accurate way of finding out.
Old 01-20-2012, 07:56 PM
Fidelis Fidelis is offline
Default
The best app for this is snapper by audioeasy. Its a great app for playing audio in the finder and it shows you on both right and left channels the peak value and peak location.
http://www.ricardomosca.com
Hackintosh, 3,7 GHz 10-Core Intel i9, 64 GB 3200 MHz DDR4, OSX Catalina 10.15.7, PT HDX 2021.6, SSL 4040G+, tons of outboard
Mac Book Pro 2019 2.4Ghz i5, 16GB RAM, OSX 10.14.6, PT Vanilla 2020.9.1
Old 01-21-2012, 06:24 AM
Sonopolis Sonopolis is offline
The TL Master Meter that comes with Protools has a logging feature. Unfortunately it doesn't come as Audio Suite (again!), so you can't do an off-line check of the peaks.
I would find an off-line check of the phase relationship of a stereo mix even more useful. These are features that are definitely missing in Protools.
Old 01-22-2012, 06:15 PM
Wait, were you meaning the peak of a whole mix? That's indeterminate in many cases. If you have even one modulation plug-in in the session that's not synced to tempo, the program has no way of knowing what its phase relationship will be on playback, and thus the mix peak is unknowable in advance.
David J. Finnamore
Nyquist was right.
[IMG] code is Off
Signal peak/distortion/db meter peak when recording enabling track on Pro Tools LE 8 hotgravy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-30-2012 10:49 AM
Peak level finder/ Spectrum Analyser veryape135 macOS 6 12-13-2011 09:20 PM
Enable Finder lordtom 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-31-2008 07:35 PM
BPM finder mike001 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-17-2005 08:45 PM
Mbox Peak / Peak Light Issue soulcatcher 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-29-2004 08:01 PM
